yes i have the orignal injectors. i do have a custom set of .330 injector nozzles but i am waiting for the clutch to go out before i replace the injectors. i have a triple turn tuning box on there (and have since about 30k miles) so i feel no need for anything other then the .330's
i did have an oil by-pass filter but i change the oil enough where i did not feel the need for it. also, the pressure drop from a by-pass worried me over the long run (maybe i am nuts but i will stick with OEM and 5k-7k changes).
everything is still what came with the car but the rear brakes at 100K.
at 4,000 miles on an oil change i run about 1/2 quart of earl.
have not checked compression but my favorite person in the world (Pete) did and i was above 550psi on all 4 at around 120k miles (i think that was the mileage). i do want to get a compression tester and if i ever do i will report it here.
yes it still runs like new with a lot of mods
. problems i have are as follows:
-right side door creaks on heavy curbs but i think that is just an adjustment.
-front sway bar bushings needed to be replaced around 75k miles but i have not repaced them yet as it is not that annoying.
-when i push in the clutch the engine note changes (guessing a throw out bearing?). the clutch is still fine and held all this winter. the clutch did slip at 122k-125k miles two winters ago but has not slipped since then
-glow plug light comes on in winter on cold days. fixed that with a coolant heater
(1000watt-Christmas gift from Rene
all in all, I LVOE TO DRIVE THE JEDI
. i cannot say enough about this car. last summer i had a loan written up for an orange New Beetle Turbo S (as a second car). i did not get it though as i knew i would never drive it since i love my TDI so much (chipped the Turbo S gets 214HP and 240-260ft lbs and i like my TDI more).
i see mileage like K5ING and just want to drive my car more. i find excuses just to drive a long distance. the thing that keeps me from that now is a bad lower back and neck problems to boot
i would probably like to get a Passat TDI and even thought about a Jetta TDI Wagon but with what the JEDI and i have been through (46 of the 48 states in part) i could not see me getting rid of the JEDI to get something with more room. i would also like to see how many miles i get before something goes out. the clutch and the turbo being the two things i am trying to get to go south. i beat the heack out of the turbo (when i nail it on the run and the boost starts to drop, i let off the pedal and nail it again to keep the boost up
). and of course, i am waiting for the clutch to go so i can throw in a Quaife and better clutch. i guess a watched kettle really does not boil
