alphaseinor
TDI Innovator, Gone but Not Forgotten
- Joined
- Jul 30, 2006
- Location
- Denton, TX
- TDI
- '03 Jetta TDI 780,000 miles (totaled out), 01 Audi TT 225 Quattro 230,000 Miles (runs great!), 00 Cabreetle Beetle dash, ALH & MK4 harness Swap
Strange things are afoot at the circle k this month!
Okay, so we get a ton of faults in the system if I floor it, or have any load on the system... it basically limp modes everything and you get to reset and drive happy to keep it from shutting down again.
Just trying to put it out there to see if anyone else has seen this before
Wednesday,01,August,2012,21:32:39:58451
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Digi Sport Performance 110A Rose Lane, Suite 104, Frisco, TX 75034
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGHH77L84D062163 Mileage: 215450km/133874miles
Address 01: Engine Labels: None
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: VWZ3Z0D7159681
Coding: 0060575
Shop #: WSC 06526 444 84896
VCID: 2952456483E2031
3 Faults Found:
18056 - Powertrain Data Bus
P1648 - 000 - Failure - Intermittent
Freeze Frame:
RPM: 1659 /min
Torque: 118.5 Nm
Speed: 70.2 km/h
Load: 60.0 %
Voltage: 13.53 V
Bin. Bits: 00001000
(no units): 1.0
18060 - Please check DTC Memory of Transmission Controller
P1652 - 000 -
Freeze Frame:
RPM: 2604 /min
Torque: 387.1 Nm
Speed: 39.3 km/h
18253 - Please check DTC Memory of Steering Electronics (J527)
P1845 - 000 -
Freeze Frame:
RPM: 630 /min
Torque: 79.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00001100
Bin. Bits: 00001100
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No: 09D 927 750 BB
Component: AL 600 6Q 0467
Coding: 0004153
Shop #: WSC 31414 000 00000
VCID: 6FE66B7C7D862D1
1 Fault Found:
01312 - Powertrain Data Bus
014 - Defective - MIL ON
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 D
Component: ESP ALLRAD MK25 0108
Coding: 0022785
VCID: 3A708A287644B89
7 Faults Found:
014 - Defective - Intermittent
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
01314 - Engine Control Module
013 - Check DTC Memory
01315 - Transmission Control Module
02053 - Control Module for Transfer Case (J646)
02054 - Control Module for Differential Locks (J647)
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
VCID: 2F66AB7CBD066D1
Part No: XXXXXXXXXXX
Component: ELV XXXX
6 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit
00668 - Supply Voltage Terminal 30
009 - Open or Short to Ground - Intermittent
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7F6D31C85D6E51
No fault code found.
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 H
Component: CLIMAtronic R/L X 3716
Coding: 0000030
VCID: 356A99145F5A571
3 Faults Found:
02508 - Temperature Sensor for Refrigerant (G454)
010 - Open or Short to Plus
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
00445 - Loss of Refrigerant
015 - Cannot Be Tested at this Time
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2703
Coding: 0111838
Shop #: WSC 06526 444 57579
VCID: 458AE9D40FBAC71
3 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
00907 - Intervention load Management
000 - -
01520 - Rain and Light Recognition Sensor (G397)
008 - Implausible Signal - Intermittent
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
1 Fault Found:
Freeze Frame:
RPM: 2310 /min
Torque: 110.6 Nm
Speed: 25.0 km/h
Load: 60.8 %
Voltage: 13.53 V
Bin. Bits: 00001000
(no units): 1.0
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00009349
Coding: 0012341
VCID: 234E574CE1CED91
Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
1 Fault Found:
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 21
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 4182FDC41B92EB1
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 P
Component: KOMBIINSTRUMENT RB4 2935
Coding: 0023231
13 Faults Found:
00461 - Control Module for Seat Memory; Passenger (J521)
00466 - Control Module for Steering Column Electronics (J527)
01325 - Control Module for Tire Pressure Monitoring (J502)
01330 - Central Control Module for Central Convenience (J393)
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
01335 - Drivers Seat/Mirror Position Control Module (J543)
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit
01305 - Databus for Infotainment
Address 18: Aux. Heat Labels: None
Part No: 7L6 819 008 B
Component: Standheizung E1MAC 0235
Coding: 0000030
3 Faults Found:
01177 - Engine Control Unit
01321 - Control Module for Airbags (J234)
01126 - Engine Speed Signal
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: F0E4E800E0B8B29
15 Faults Found:
01320 - Control Module for Climatronic (J255)
01327 - Control Module for Parking Aid (J446)
011 - Open Circuit
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1700
VCID: 040C34D044003E9
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F06BB3C2DE65D1
1 Fault Found:
Address 29: Left Light Labels: 3D0-909-157.lbl
Part No: 3D0 909 157
Component: EVG GDL+AutoLWR(l) X012
Coding: 0000003
VCID: E6C88E58D27C6C9
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 B
Component: SG-Quersperre 5018
VCID: 3776931C4556A51
6 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
014 - Defective
01316 - ABS Control Module
Address 34: Level Control Labels: None
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
VCID: 36689E18425C5C9
2 Faults Found:
Address 36: Seat Mem. Drvr Labels: None
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7L6 919 887 DX
Component: Navigation 0736
Coding: 0000002
Shop #: WSC 06526 444 59033
VCID: 9F46DBBC4DA67D1
Address 39: Right Light Labels: 3D0-909-158.lbl
Part No: 3D0 909 158
Component: EVG GDL+AutoLWR(r) X012
Coding: 0000003
VCID: E7D6835CD576751
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
Shop #: WSC 25166 444 98490
VCID: 3E7886386A6C949
Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0201
8 Faults Found:
01134 - Alarm Horn (H12)
011 - Open Circuit
00486 - Front Passengers Outside Door Handle Central Locking Button (E370)
007 - Short to Ground - Intermittent
00130 - Right Rear Inside Door Handle Illumination (L134)
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: F1E2ED04EBB2BB1
1 Fault Found:
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 AX
Component: Radio 0736
Coding: 0005077
VCID: 8912A5E4E322E31
Address 65: Tire Pressure Labels: 7L6-907-273.lbl
Part No: 7L6 907 273
Component: Reifendruckueberw. 0052
Coding: 0210390
Shop #: WSC 03155 444 54064
VCID: F5EAD9149FDA971
2 Faults Found:
01507 - Initialization Not Successful
000 - - - Intermittent - MIL ON
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - Intermittent - MIL ON
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000003
1 Fault Found:
01024 - Rain Sensor (G213)
014 - Defective
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B7E8F2C797E811
1 Fault Found:
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 B HW: 3D0 035 617 B
Component: Telematik NAR1 0104
Coding: 0076510
Shop #: WSC 06531 406 00561
VCID: 1F465BBCCDA6FD1
2 Faults Found:
004 - No Signal/Communication - MIL ON
00003 - Control Module
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
VCID: 387490204848AA9
2 Faults Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
End ---------------------------------------------------------------------
Coding: 0060575
3 Faults Found:
Freeze Frame:
RPM: 1659 /min
Torque: 118.5 Nm
Speed: 70.2 km/h
Load: 60.0 %
Voltage: 13.53 V
Bin. Bits: 00001000
(no units): 1.0
P1652 - 000 -
Freeze Frame:
RPM: 2604 /min
Torque: 387.1 Nm
Speed: 39.3 km/h
P1845 - 000 -
Freeze Frame:
RPM: 630 /min
Torque: 79.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.32 V
Bin. Bits: 00001100
Bin. Bits: 00001100
Coding: 0004153
1 Fault Found:
Coding: 0022785
7 Faults Found:
Coding: 0131304
Component: ELV XXXX
6 Faults Found:
011 - Open Circuit
011 - Open Circuit
011 - Open Circuit
Coding: 0000030
3 Faults Found:
Component: 2703
Coding: 0111838
3 Faults Found:
000 - -
Coding: 0060575
1 Fault Found:
Freeze Frame:
RPM: 2310 /min
Torque: 110.6 Nm
Speed: 25.0 km/h
Load: 60.8 %
Voltage: 13.53 V
Bin. Bits: 00001000
(no units): 1.0
Coding: 0012341
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 21
Reset counter: 39
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:60:00
Coding: 0000232
1 Fault Found:
Coding: 0023231
13 Faults Found:
011 - Open Circuit
Coding: 0000030
3 Faults Found:
Coding: 0000006
15 Faults Found:
011 - Open Circuit
1 Fault Found:
Coding: 0000003
6 Faults Found:
014 - Defective
Coding: 0015521
2 Faults Found:
Coding: 0000002
Coding: 0000003
Coding: 0000085
8 Faults Found:
011 - Open Circuit
1 Fault Found:
Coding: 0005077
Coding: 0210390
2 Faults Found:
Coding: 0000003
1 Fault Found:
014 - Defective
1 Fault Found:
Coding: 0076510
2 Faults Found:
2 Faults Found:
