vavulaka
Hi everyone, I'm new here so forgive my ignorance.
I recently bought an 03 Jetta TDI.
The man I bought the car from is a diesel enthusiast and took good care of the car. I've owned it since September 2012 and so far the only problem was a bad thermostat that I had to change in late September along with a new coolant temp. sensor.
Here is where I'm having problems:
A few months back I started getting the coolant indicator light on my dash, I would add some and it would go away for a few days, however these "fill-ups" became more frequent. The coolant reservoir seems to constantly be empty.
I've looked about to see if there are any leaks and did notice that I constantly have a "wet spot" underneath the passenger side headlight. I checked the reservoir itself to see if it had any cracks and it's fine. I can't find any hoses that are leaking or seem wet anywhere. The leaking seems to be confined to the area under the reservoir so I'm a bit confused as to what is going on.
I was told that it could be an air pocket somewhere since the coolant only leaks when the car reaches its ideal temperature. I also noticed that when the car is warmed up, the hose coming from the top of the radiator is very hard (under a lot of pressure it seems) this makes me think that perhaps there's a clog somewhere? Should I try draining the system?
Anyway, I hope you guys can help me out here.
Thanks!
Thanks!
