Old November 27th, 2007, 19:15   #31
paramedick
paramedick's Avatar
Default Deciphering VW security lug bolts
Lost your lug nut security key? Wanna know how to remove it? Pick one up at your dealer for $20 or less.
Two types of grooves available in the lugs. Star grooves and Square grooves.
Use the part number listed and add the code to the end of it.
Star Groove
8D0 601 139F
Code Grooves
000 10
001 11
002 13
003 14
004 15
005 16
006 17
007 19
008 20
009 21
Square Groove
8D0 601 139E
Code Groove
051 6
052 7
053 8
054 9
055 10
056 11
057 12
058 13
059 14
060 15
061 16
062 17
Old December 1st, 2007, 11:10   #32
vwlogue
vwlogue's Avatar
Default Battery Replacement
A4 Battery replacement write-up: Battery Replacement: howto, battery options
This question comes up all the time (especially when it gets cold!). It might help listing it on the first post. Thanks WN.
vwlogue is offline   Reply With Quote
Old January 9th, 2008, 04:34   #34
sodapop6620
sodapop6620's Avatar
TDI(s): Jetta 2000
Fuel Economy: about 57 avg. lately
Talking Foglight Wiring by Tongsli
When you upgrade your headlights with headlights that include fogs when you did not have fogs before this is the page to look at.
http://forums.tdiclub.com/showthread.php?t=37585
Thanks for the writeup.
2000 Jetta 5sp 360,000 plus Nov 08
2/05 Mileage contest winner 59.942 MPG @ 55MPH indicated
4/05 Mileage 3rd place 59.76 MPG @ 60MPH indicated
sodapop6620 is offline   Reply With Quote
Old January 10th, 2008, 11:06   #35
A_Shifter
Default 5 brake light mod
Originally Posted by 04PDWagon
5 light mod on the Jetta Wagon link disappeared...anyone else have it that can post it up?
Here's one: http://georgejacob.50megs.com/fab.htm
2003 Jetta TDI Wagon
A_Shifter is offline   Reply With Quote
Old February 18th, 2008, 08:04   #36
Ksf
TDI(s): Zora
Here are links for the serpentine belt replacement and coolant temperature sensor replacement done on 04 PD so the engine is a BEW. I took lots of pictures as my communication skills are poor.
Belt - http://forums.tdiclub.com/showthread.php?t=200104
Sensor - http://forums.tdiclub.com/showthread.php?t=201212
Glad this is not like 55nm NPN material because being able to touch it is very satisfying....
05 Tora (T=B)
Ksf is offline   Reply With Quote
Old April 1st, 2008, 19:18   #37
colroc
TDI(s): 2004 golf pd
Default PD upper boost pipe Repair
On my 2004.5 Golf, the rubber boost pipe attaching the intake manifold to the plastic bit coming from the intercooler is held in by a metal clip that locks the pipe in with a set of tabs on the flange.
Over time this Spring steel clip can wear the aluminum tabs off, which will allow the pipe to pop out.
Yesterday My pipe blew off because both of the tabs on my pipe looked like this
Vw wanted $125 for a replacement, which I though to be unreasonable, especially since it seems that this part was designed to fail... (steel clip holding back aluminum tabs in a high vibration environment)
So I came up with the idea of using some self tapping screws to replace the tabs.
I used some short screws with a 1/4" head, which then had to be filed down to fit, since they are just a little bit bigger than the original tabs.
It took a lot of patience and a bit of trial and error to get the fit just right.
You'll know you've got it right when you hear the metal clip snap into place and you won't be able to pull the pipe out without taking the clip off first.
I probably don't need to mention this, but make sure to clean all the little bits of metal out that are made by the screws drilling theough the flange.
colroc is offline   Reply With Quote
Old April 1st, 2008, 19:28   #38
whitedog
There are other, more permanent options. See signature for more information about doggie collars.
Old May 23rd, 2008, 14:52   #39
lglamb
Default Manual Tran Shift Cable Carrier
A few of us have had the plastic "Carrier" (at the tranny end of the upper shift cable) break.
Here's part photo and parts blowup.
Also shown is small pipe wrench that makes it easy to lift that locking tab, just fit it on the protrusion and lever it up.
Not a write-up, but pretty straightforward to figure out. Need to unbolt the lower cable to
slide the Carrier (#50) out and back in the metal bracket (#49). The bracket is loose without the Carrier, make sure you align the slider part (of bracket) with slidee part (#45).
lglamb is offline   Reply With Quote
Old June 14th, 2008, 15:58   #40
Wallace
Wallace's Avatar
Fuel Economy: 45ish
Default Mk4 Rear Axle Bushes.
Here is another rear axle bush How-to, done by me and my mate Rubberdubber on www.scottishvag.net/phpbb3 here in Scotland, maybe one of your mods could add it to the other one in the relevant section. It is an 'on car' procedure for replacing original bushes with Powerflex polyurethene bushes, weather here is a lot damper/colder and cars not in quite so good nick underneath (it is an everyday driver car though) as you will see from the pics; http://www.scottishvag.net/phpBB3/vi...?f=101&t=24344
We have just started up the How-to section in the last month or so and already there are some interesting things on there, so have a look.
Hope you find it useful, Thanks,
Wallace
Everything seems easy, until you try to do it!
Wallace is offline   Reply With Quote
Old June 22nd, 2008, 07:46   #41
milehighassassin
milehighassassin's Avatar
Fuel Economy: 43
Default Door lock switch/dome light fix (link stolen from original TDI Club thread).
http://www.taligentx.com/passat/main...lockmechanism/
I like this one much better because it has pictures and is organized in one place.
http://www.hardeysmotorwerks.com/
http://www.20vturbo.com (R.I.P)
2005 Golf TDI PD, FM100, Frostheater, Hidden Hitch,
Clear-bra, Tint, VR6/G60 Clutch Combo, EuroJet SMIC, Custom Lower intercooler Pipe, VNT-17, Panzer Plate
Custom 3" turbo-back exhaust
milehighassassin is offline   Reply With Quote
Old July 2nd, 2008, 16:03   #42
aNUT
aNUT's Avatar
Fuel Economy: Great.
Default How-To R&R Advance Solenoid / N108 / Cold Start Valve
http://forums.tdiclub.com/showthread...18#post2198118
www.dieselland.net
aNUT is offline   Reply With Quote
Old August 5th, 2008, 18:38   #43
Ricosuave
Ricosuave's Avatar
Apologies if posted before - a forum for vw's that you can ask bentley manual publisher technical questions
http://tech.bentleypublishers.com/ca...a?categoryID=6
Now: 00 Golf TDI, 02 Audi Allroad, 02 2500HD Duramax, 09 JSW TDI, 10 Touareg TDI
Then: 69 SC Transporter, 84 Rabbit GTI, 87 Fox GL, 91 Golf IDI, 96 Passat Wagon TDI, 97 Jetta IDI, 03 Jetta Wagon TDI
Ricosuave is offline   Reply With Quote
Old August 28th, 2008, 10:18   #44
sootwagen
sootwagen's Avatar
Fuel Economy: Who cares???
Originally Posted by Ricosuave
the 5 brake light mod for jetta wagons is out - anyone know where else it can be found (with pics and info specific to the wagon?) - or if any wagon owners have done this, can they provide the pin info details?
I found this:
http://s90139951.onlinehome.us/vw/rearmod.htm
Hope it helps.
(O8)==(\X/)==(8O)
2003 Jetta GL Wagon TDI 5spd, Indigo Blue
sootwagen is offline   Reply With Quote
Old October 4th, 2008, 23:48   #45
tothemax
tothemax's Avatar
Default Simple Puller to help remove ECU
Good Write up here on pulling out the ECU http://www.goapr.com/VW/support/ecu_..._gti_jetta.pdf
I used a couple variations (from other members) that helped me:
stick one can in:
Then another:
Now I can access the connectors and the front of the ECU. Once I disconnect both connectors, I use my coat hanger. 1x2 puller to easily pull our the ECU.
I hook each one of the loops in each of the pins on the ECU and it pulls out easier. Straight pull. Tired of scraping my knuckles. Have fun!
tothemax is offline   Reply With Quote
Where's all the threads LMJ Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 24th, 2013 19:59
Got some new threads... velociT General VW Discussion 5 August 8th, 2008 23:15
Want to get really old threads... BeetleGo TDIClub and TDIClub Forum News, Issues, Problems and Suggestions 2 October 5th, 2006 06:02
All of the Epsilonian threads are gone! valois TDI Power Enhancements 1 November 3rd, 2000 00:15
Page generated in 0.19699 seconds with 10 queries
[Output: 137.44 Kb. compressed to 114.42 Kb. by saving 23.02 Kb. (16.75%)]
