WTS 1996 Passat TDI (1Z) - Long Island, NY
bringsaber
Hudson Valley, NY
1996 Passat
Pics of car
Just kind of putting out feelers for my TDI, started a new job recently so I don't have time to work on it or drive it as much as I should.
Has ~177k miles, runs and drives great.
In the last 2k miles it has had
-Timing belt/water pump done
-New brake lines and brakes
-Injection pump resealed
-Front left ball joint replaced
-AC/Heat blend door fix
Cons:
-Headliner board is there but no headliner
-Rear defrosters do not work currently
-No engine cover
-Scratches and light rust from being a 26 year old car
-Roof paint is a little rough, seems like was attempted to be repainted
-Passenger door doesn’t open from outside and has window off the track issue(working on fixing those currently though)
Asking 4500, not jumping to get rid of it but I am negotiable.
bringsaber
Hudson Valley, NY
1996 Passat
how are tires? any maintenance you would recommend? yes, interested.
Tires aren't bald/dry rotted or anything but not brand new either. As for maintenance, had a guru from the list (People II auto) up in Highland, NY when I lived there look over the whole car as well as do the major maintenance listed above(Timing belt, Injection Pump, ball joint). Besides the few things I mentioned in the Cons list, the car runs pretty great.
Roughly where are you located? Can PM me if you want to come check it out if close, I am in the Western Suffolk area
