HI there,
i'm modifying the ECU file with Winols beacouse a slow down sudder issue after the ASV injection pump installation.
Several months ago i read a tutorial wrote by Nexus (thanks to Nexus for this great tutorial) in ecuconnections, he explains how to extend the limits for the diagnostic software in it. I want to change the max boost pressure limit that diag software can see, that's 1650mbar in my file. I want to set it to 2060mbar.
Tutorial says to change all the 8bits '018 255' occurrences to '008 XXX' (xxx=120 for absolute pressure of 3060mbar). Winols show me 4 results. I changed them with no problem to '008 120'.
Tutorial says about a 16 bit single value that's necessary to change it too. That value is '980'.
It says too,that it's a bit after the '018 255' occurrences(for edc15 ecu), but there's two '980' 16bit values after those occurrences in the original file(msa15 ecu), and 5 before them. I suppose it's one of the two last values, but,which one?
I need to identify it and scaling it to 833.
Can somebody point it to me the address for that 16bit value please?
I read in other thread:
' Look for 0 980 0 x 0 980
X usually = 10000
Change both or just the second 980'
But i can't find any 0 980 10000(or another number) 0 980 sequence in my file...
AFN engine '97, MSA15 ecu, 028906021EK
Addresses with the 16bit '980' value:
-13D94
-14BC8
-14BCE
-396A6
-3ACD2
-3C0B2
-3C12C
Addresses with the 8bit '018 255' value:
-17F96
-3AE5E
-3AE62
-3AE8A
THANKS IN ADVANCE
X usually = 10000
-13D94
-14BC8
-14BCE
-396A6
-3ACD2
-3C0B2
-3C12C
-17F96
-3AE5E
-3AE62
-3AE8A
THANKS IN ADVANCE
