whitedog
This isn't a TDI - it's a 96 Mazda 3.0 - but the theory holds the same. Replace everything that the timing belt touches. This timing belt was done a few years ago at the dealer where they replaced the belt and tensioner roller and nothing else. I don't have mileage on when it was done, sorry. They got lucky though. They thought it was just a Vbelt idler that was making noise but when I saw the idler and the belt had worn holes in the plastic cover, my TDI experience took over and I knew what was going on. Fortunately, the cams were off less than half a tooth, but it could have ended bad. OK, it's in an MPV, so it wouldn't be a huge loss to the world, but it would be to the owner.
BTW, Very easy TB to do. The water pump doesn't touch the belt, but the bearings felt a little loose and it was cheap and easy to do right then. Without the water pump a first timer could knock it out in two hours.The water pump may add half an hour with cleaning the old gasket off.
