What To Do With VCDS
Zak99b5
Albany NY
2003 Jetta TDI
I borrowed a buddy's vcds (changing out the IP and need it to fine tune timing afterward) for a few days.
I would like to take advantage of it and do some other changes, such as set it to unlock all doors with key off (not just driver's). No clue how to do that though.
Is there anything else I should do with it before I return it? Say, lower egr duty cycle? My car is a stock 03 with manual tranny with 222k miles, running well.
While vcds is obviously a powerful tool, I find it not very intuitive to use, and since I don’t own my own, I don’t have an opportunity to play around with it and get comfortable with it.
Tdijarhead
Lawrenceville PA
To change the door locks go to comfort control module and click up through the blocks I think it is block 4-8. Hold the courser over the block and a little pop up box will tell you the acceptable values and what to change.
gmenounos
Watertown, MA, USA
Assuming that the VCDS cable you borrowed is compatible with the Ross-Tech VCP drivers ( https://www.ross-tech.com/vag-com/usb/virtual-com-port.php ), you could install kw1281test and use it to pull the SKC from your cluster. Useful if you need to add/replace any keys or if you ever need to replace the cluster or ECU:
You can also use kw1281test to enable the "Roll up/down the windows with the key fob" feature.
Zak99b5
Albany NY
2003 Jetta TDI
Tried that and I think I found the right block but I got a “not oper” in the boxes.
Zak99b5
Albany NY
2003 Jetta TDI
It’s a Ross tech hex-can cable. I know what the SKC is in a general sense and would like to get it if I could from the car for the reasons you mention, but this seems a little above my pay grade as far as computer skills?
