ereeves
Apologies if this has been answered elsewhere, but I've been searching for hours and can't find the answer. I've got an '03 Jetta Sedan, and I'm curious if anyone knows what is/was/could be mounted OE in the mounting holes on the left (driver's) side in the trunk underneath the parcel shelf. To clarify, I'm not referring to the Monsoon amp and mounting cage/bracket on the right side. It looks like there are holes for a similar mounting setup on the left side, and I'm curious as to what that is/was. If there's a similar/matching cage/bracket for the left side, that would be great. I'm looking to mount the crossovers for aftermarket component speakers and a power inverter while keeping the appearance as close to factory as possible. I can do one or the other inside the Monsoon cage, and if there's something similar for the left side, my problem will be solved. Thanks in advance.
