Wilkins
I'm wondering if anyone thinks any issues are indicated by these logs. Car starts well, but runs a wee bit rougher when first started than when fully warm. For the last 3-4 years it seems to me that it has been a bit rough at very low revs either on overrun or under power, at least compared to my CR. Overall the car runs pretty well with good power, quite smooth over 1800-2000 rpm. I think the tandem pump gasket is leaking and the exhaust might have a small leak in the flex pipe - it is noisy when cold but quiet once warm. I've been trying to figure out if anything is going on for a few years, since it is not as smooth as it once was, have found and fixed a number of small issues but I still think something else is going on.
I have not looked at the cam yet this year but last year it seemed ok
It seems to be cylinder 1 that is moving around erratically, I tried to indicate that the log plotting application put the scale for cyl 1 on the right while the other three cylinders have the scale on the left.
Click on the photos for full size images
Any thoughts?
Any thoughts?
