GlowBugTDI
- Joined
- Jul 20, 2018
- Location
- Cambridge, MN
- TDI
- 2001 Beetle GLS TDI (BIODSL). 01 original Glow Bug TDI (sold)
I like this idea, but im with mongler their expensive for my use. Im just trying to filter used engine oil for an alh motor to eat slowly. Alao possibly filtering biodiesel if i get there.CAT makes some 2 micron filters. Check the filters referenced in the site below. Some here have used them as well.
Ditzle mod?I run PCS 1000 in my parts washer and i run a Walmart cheap oil filter that goes into a Baldwin BF7633 (2 micron) filter. they are cheap and work great.
Ditzle mod on my HF parts washer with PCS 1000 is epic.. still the diesel soot turned it black as its way under a sum 1 micron in size...... never getting that out.. 4 years of normal DIY shop use and its still stripping whatever is on parts off like it was new. Filters last about 10 hours of use. so about 4 a year for my use. PCS 1000 is basically a refined solvent bases kerosene or similar to diesel. I usually let my parts washer settle for a month then drain it... LOTS of sediment that would normally clog up the filter... always draw from a few inches above the settling line!
i know not the story you need but those baldwin fitlers are awesome and could help you. CAT is stupid expensive and the ones i used did NOT last. they are NOT rated for the use i had or i got some counterfeit ones or something..
It was just a suggestion for a filter. Use whatever you want.I like this idea, but im with mongler their expensive for my use. Im just trying to filter used engine oil for an alh motor to eat slowly. Alao possibly filtering biodiesel if i get there.
Yes, and thank you for the advise! I appreciate itIt was just a suggestion for a filter. Use whatever you want.
Agreed, but during the summer months i should be golden right? As long as i stop well before freezing weatherNot something I would try in a cold climate either. Now here in Texas things are pretty warm most of the year. Finding a legitimate supply is always tough now.
Yes. When done correct to an older engine alh and older... with a massive upfront cost.... sure.As philngrayce said. I've been fueling my 2002 Jetta with wvo since 2008 with a two tank Frybrid system. I have driven about 400,000 total miles of which about 350,000 has been on 100% wvo. Those that say it will destroy your engine don't know what they are talking about or really know the fundamentals of diesel engines.
Yes, there was upfront cost. Back in 2008 the system I installed cost around $2000. The system paid for itself the first year. That was 14 years ago.with a massive upfront cost
Not as much as you think. I have dealt with large low speed diesels in excess of 32,000 hp that are designed to burn 600cSt HFO. It is all about operating within design parameters. In this case fuel, specifically fuel viscosity.Big difference between those engines and a VW TDI
Yes, that is very true. But you are the one who brought it up.Everyone values time differently. To each their own!
I consider this endeavor a bit of a hobby. One that has conservatively saved me $25,000 in fuel I didn't have to buy.Your time is a investment into whatever your doing.
An inaccurate and poor assumption.If you spent the same time you did on veg oil and the cost... putting that into gold coin or S&P500 would pay off better.
