TDIJetta99
Make sure the injection timing is in the upper half of the graph in VCDS too.. Really makes a difference in super low temperatures..
Here are my stats:Make sure the injection timing is in the upper half of the graph in VCDS too.. Really makes a difference in super low temperatures..
Volts are different than amps... if the battery is taking the cold hard, that could be a big problem, which seems apparent since jumping it took care of it.Mine did not start at all. Glow plug harness is bad though. Jump started and it start after few cycles. Checked batteries and had 12v before starting. OEM batt is 5yo.
Tried again at noon and started right away. Bought DFS suspecting might have gelled up. Will see if it happens again tomorrow AM.
5.8-6.2 isn't a timing number unless you're just looking in group 4, but that doesn't tell you where the pump is set... Go to measuring blocks, group 0, click basic settings, click "tdi timing" and a graph pops up.. You want it plotted as close to the green line as possible.. Do this at operating temperature..Here are my stats:
Checked the injection timing (5.8 - 6.2) and injection quantity (6 mg/stroke). I think the timing was in the middle.
This seem about right, or low?
That's not too bad. My PD smokes much more than that when started cold at 25 degrees F. Has smoked like that when it was brand new with about 2000 miles on it by the first winter.Here's mine this morning.. -5F.. Car has been sitting for 5 days.. LOL the door was a little frozen shut.. One bad glow plug, low compression pistons and a race cam..
This video is proof positive that you don't need 200rpm cold to get fuel...
http://youtu.be/jv24TNX50sw
Edit.. Here's how the 24V VR6 started 2 minutes prior..
http://youtu.be/oBkkt72ooNs
The only way to tell if a battery is good using a volt-meter is by measuring the voltage while cranking. It may well show 12V until you put some load on it, if the voltage drops to 10V one of the cells are dead.Volts are different than amps... if the battery is taking the cold hard, that could be a big problem, which seems apparent since jumping it took care of it.
Think of it... if the battery is weak, it won't heat the plugs as much and it will not push the starter as quickly and powerfully. Double whammy.
I agree. The older the battery the more the voltage will drop during a cold start. An old, tired, battery may still work perfectly fine a year or two if the temperatures are warm enough.Temperature will affect cranking volts as well.. A fully charged car battery should read 12.65V with no load on it.. Typically you want to see 11V+ while cranking, but in bitter cold temperatures after a long glowplug cycle, 10.5-10.8 isn't terrible if it's cranking at a semi-normal rpm.. You won't get 200rpm in single digit temperatures (see the video I linked a few posts up), but you should get something..
Hey Jamie! Check out a Passat during your test-driving adventures.-50C. Yep. That was street parked, with no plugging in. It's just about 13 years old and started in -38C last week, but not without complaint. But I am sad to say her days are numbered. I have never been this upset about parting with a "thing". Maybe it's because she has a name, "Plucky". Drove a new gas model and a diesel today. Going back Monday to look again... sigh. I will miss this car.
Jamie
It started at that temp with 4 dead glow plugs? Or it started with 4 working glow plugs and no coolant heater?-50C. Yep. That was street parked, with no plugging in. It's just about 13 years old and started in -38C last week, but not without complaint. But I am sad to say her days are numbered. I have never been this upset about parting with a "thing". Maybe it's because she has a name, "Plucky". Drove a new gas model and a diesel today. Going back Monday to look again... sigh. I will miss this car.
Jamie
No coolant heater plugged in. No way it would have started with 4 dead glow plugs - not without a blow torch or something.It started at that temp with 4 dead glow plugs? Or it started with 4 working glow plugs and no coolant heater?
That is why i asked for clairification. I have no idea bow mine started at 18 deg F with all 4 dead. When i removed them i figured maybe 1 was shot but not all of them. I wanted to know if anyone else has expirienced a start at that temp or lower with all 4 bad.No coolant heater plugged in. No way it would have started with 4 dead glow plugs - not without a blow torch or something.
