alluneedizshagbaby
- Joined
- Aug 3, 2002
- Location
- Denver
OK guys...here are the results:
Well was not the Battery. I bought a brand new 825 Crank Amp Battery (could not use my wife's cause of Post Orientation) and made no difference. I suspected it might be Battery because of what 'n1das' said and because of what I saw: very low electrolytes and Trunk Button not activating.
And it was not the Starter based upon the TEst I performed curtousy of 'Just Some Guy' (Thank you!!). I jumped the Starter Solenoid to the Positive Terminal while my wife Turned the Ignition and whalla!! Heard the Purr!! Won't start without me Jumping Solenoid to Pos Terminal.
So as a couple of you guys metioned, looks like the Ignition Switch is 'TOAST' and I did identify (curteousy of 'brownnugen') the N75 that is clicking continuously when the key is turned over. I don't know if N75 is the Ignition Switch or a Relay associated with the IGnition Switch.
The thing I'm still puzzled about is why can't I still open the Trunk with the Trunk Button even when the engine is running?
Is the Trunk Relay/Solenoid tied into the Ignition Switch somehow?
So so far it looks like the Ignition Switch but I'm still mystified by the Trunk Solenoid/Relay still not functioning.
Any clues? If everything ties into the Ignition Switch then is that something I can fix without special tools? Approx cost to replace? Do I need to special order or must get from Dealer or can I easily find?
In the mean time, I'll be reviewing the Ignition system in my Bentley Manual. (Engine 1Z) I don't know whether it's OBD D or OBD II.
