tongsli
Most of us here who have installed an MFD into their MKIV's, whether it be a Unit D or G have all used the Gala wire/speed sensor wire from the cluster to the Navi.
There has been some discussion on VWNavi.com about how to properly set the MFD.
I was hoping to start this thread so that those of you with MFD's can post how you have configured your Navi.
Most of us set the pulse to 8 and the tire circumference to whatever your size wheel. Press 3 & 6, then the flag button. This should bring up the configuration menu. You can also do this via Vag-com.
From a post on VWNavi.com
Our MFD's use Dead Reckoning to navigate so here's a definition:Tyre circumference is just an additional calculation used in the navi for short distances when approaching junctions and when there is no GPS signal. The navi updates the initial value entered so its self correcting. The navi doesn't continually monitor the satellites but refers back to them periodically to check the car's actual position in relation to what the gala and gyros are telling it about your car's position.
More posts from VWNavi.com:Dead reckoning (DR) is a method of navigation used in ships, aircraft, trucks, cars, rail engines, construction sites engines e.g. in tunnels and, more recently, mobile robots. Essentially it is used to estimate an object's position based on the distance it traveled in its current direction from its previous position.
A navigator using this method uses the craft's last known position (fix), then plots the craft's expected position for a given fix interval (elapsed time from one fix to the next) according to the compass course it is steering, the speed it is making, and allowance for winds and tides. In modern navigation, this plotted position is compared to a fix, taken at the time for which the DR was plotted, to determine set and drift (the combined external forces which act upon a ship causing it to deviate from its intended course). The difference between actual position (fix) and DR position helps the navigator determine a course and speed that will allow for set and drift in maintaining the ordered course and speed of advance.
You should use 8 if you use the GALA pulse and as I said the Navi calibrates the tire size automatically. What do you mean by truly accurate, it will not be any more accurate than about 5 meters unless you are military or a land surveyer. That's the techology limit for automotive use at present. As long as it updates within about 5 seconds after a left or right turn you are at the best you can have.
The Navi adjusted the tire size. I would advise you to change the pulse to 8 if you are having problems with accuracy.
I am on my second car with a Blaupunkt built Navi and they are working fine if they update about 5 seconds after you turn a corner, i.e. the map/arrow show the correct direction. I would then stop worrying about it.
Apart from there being a bit of a lag before the Navi displays the actual position, as others have mentioned, I find it quite accurate. On my system the cursor is always centred on the road. I also try to think of the arrow point as being the REAR of the car because that is where my GPS antenna is located.
Don't bother messing with the tyre circumference as the system will always adjust it. I have also found that if the GALA setting is wrong, the Navi will get completely lost, not just a bit wide.
If you use the GALA pulse then the correct setting is 8, but if the Navi is connected correctly then it calibrates itself in about 10-15 minutes.
However, you are still missing a connection if the Navi doesn't update properly.
If all is well then a good test is to take a drive and see how fast the Navi notices that you have turned a corner. My old Blaupunkt DX-N which is essentially an MFD, and my new MFD 2 notice within 4-5 seconds that I have changed direction and the car position symbol changes appropriately. Does your Navi do this? If it does then the Navi is working as it should. If it doesn't then you still don't have GALA.
Does it tell you to prepare to turn in so and so many feet and then when you are at the turn does it tell you to turn for instance "Turn next right"? If it does then the Navi is working as it should. Or are you well past the turn when you get the turn instruction? Then you still don't have GALA.
Have you confirmed that you have SAT acquisition? It can not calibrate without the Sats. The Navi needs minimum 2 Sats and 3 Sats for a 3D fix which gives altitude.
So and now the last question (you have A GALA signal) otherwise the radio volume will not change. Using two 3M vampire clip connectors you have to take a wire from pin 1 where the GALA pulse is on the Navi and connect this to pin 5 of the 26 pin connector. If you do this it should fix the problem,
There is a picture diagram of each connector on the back of the Navi. If you don't have such pictures on your Navi then look here : http://www.linux-profis.de/navi/Rad...elegung_mfd.pdf
