greenzuki
Hello,
I'm newbie at TDI. Searched and read a lot of posts, but nothing helped me.
Maybe someone can give me a direction?
For 2 years I had a problem with starting a car. It doesn't matter was it warm or cold. There was a MIL on all the time and in summer/winter glow plug light were on only for a second.
I've tried to do http://forums.tdiclub.com/showthread.php?t=328868 this write up. It really helped me with cold start in summer. No problems. But glow plug light still come on very short. When it is very cold I'm starting to have start problems.
I changed new glow plugs, new fuses, new glow plug relay, new CTS. Nothing helped. When I unplug CTS vag-com shows me -5,9, glow plug light still go off after a second. It didn't help. I cleaned all possible connections, except glow plug harness, which goes on top of glow plugs.
The only code i get from vag-com is
17055 / P0671 code (Cylinder 1 Glow plug circuit (Q10))
17056 / P0672 code (Cylinder 2 Glow plug circuit (Q11))
17057 / P0673 code (Cylinder 3 Glow plug circuit (Q12))
17058 / P0674 code (Cylinder 4 Glow plug circuit (Q13))
It changes all the time, it is cylinder 3 or cylinder 4.
but when I clear it it stays off for about 5-7 start ups. But still no progress in glow plug period.
Tried to change glow plug period through vag-com, but changing values didn't help. vag-com shows 1.61 sec. glow plug period all the time, doesn't matter what I do. I even tried to disconnect fuel temperature sensor, intake air temperature sensor along with CTS didn't change a thing.
Any ideas? In 2 months it will be cold in my country, want to fix this issue.
