edge130
Received in mail today letter stating extended warranty for the hpfp
"Warranty Extension for High-Pressure Fuel Pump
Certain 2009 - 2012 Model year VW TDI clean diesel engine vehicles
"...to extend the warranty of the high pressure fuel pump (HPFP) in your TDI clean diesel engine vehicle under specific conditions to 10 years or 120,000 miles, whichever occurs first, from the vehicle's original in-service date."
"The warranty extension covers the diagnosis and replacement of the high pressure fuel pump only if:
your vehicle has a VW approved misfueling guard installed and
only of correct, uncontaminated fuel is present in your vehicle."
"...the dealer will inspect the fuel filler neck for a correct misfueling guard. If the misfueling guard is present, your dealer will then analyze a fuel sample from the vehicle to determine if the correct, uncontaminated fuel is present. Upon confirmation of both the misfueling guard and correct, uncontaminated fuel, the high pressure fuel pump will be replaced at no cost to you, as long as the vehicle remains within the time and mileage limit of this warranty extension."
Hopefully another extended warranty notice will be arriving covering the DMF.
