chopchop
- Joined
- Apr 24, 2000
- Location
- Here (Calgary) & There (Blighty)
In another thread, I have highlighted the problems with premature rear brake pad wear.
Here's another observation:
The front pads are fitted with wear sensors, the rear's aren't.
Why fit the sensors to the fronts when it is the rears which habitually wear out first?
Another observation:
Pad thickness:
Bentley says 12 mm for rears. These are the ones which the dealers charge out at $102 Cdn.
Standard ones from Cantire ($25) are 15 mm thick
Premium ones from CanTire ($55) are 17 mm thick
The backing plates are all about 6mm thick.
So you'll get a max of 4mm useful wear out of the VW ones, 7 mm of useful wear out of the CanTire el cheapos, and 8 mm out of the CT Premiums.
Christ, VW's ripoffs become more blatant & obvious by the day.
- Richard
Pad thickness:
- Richard
