VCDS VAG-COM Locator
DieselJeff
Nashua, NH
'10 Jetta 6MT & '11 Jetta DSG
Sorry for the huge delay for all those posted here as well as the PM's received. Everyone is added/location updated. Thank you and have a great New Year!
Thank you Wingnut for cleaning up the thread earlier this month.:D
morre
Windsor CT
96 E350 7.3, 95 S300 TD
USB-HEX-CAN and other scan tools for every make and model and every control module in a car.
Also i can read Security Access Code(PIN) if you need your keys to be programmed
Windsor CT 06095
babydoll
wv
01 jetta 5 spd 01 golf 5 spd cruze diesel 9 spd auto 17
not sure where to post this so i will start here,
thinking about buying a vag com, have a 01 golf and a 06 jetta right now a i need a key programed and have a air bag light on , thought i might save some money in the long run and learn something at the same time . have a small laptop, what kind of money ? where do I get it? thanks all help appreciated.
csnow
Ohio
Ross tech is where you need to get it unless you find a used Ross tech. I think you'll need the hex-can USB to be able to use it on both cars. But you can searched the Ross tech website for that.
Sent from RAZR using Tapatalk
Squrrell
Raleigh, NC
2005 Golf TDI
I will gladly meet people, scan codes, reset, adjust settings as the person has researched. if I have to look up how to set something up, research how to code a radio/cluster, or perform more than basic diagnostics, then likely that will run into the "Beer money" fund and likely to burn time I would be doing other things.
Some people think every guy with a VAG com cable is an automatic guru. If you think you need a mechanic then likely you do.
I second this sentiment. I only have VCDS Lite (Registered Version) and a homebrew interface, but it should serve about 95% of most people's needs up through 2005 models from what I understand.
Dan89
Windsor ON
02 Golf
Hi,
New to TDIclub, not new to TDIs,
I have a copy of vag com version :
VCDS License
with HEX-USB+CAN Interface
Windsor ON
postal code N9A 1S6
CRM
NC
09 Jetta
Vcds
Have Ross-Tech USB-HEX-CAN
Just got it, 0 skill level with it (as of yet), but could use some experience if you want to be a guinea pig :D
PM me if interested.
Durham, NC
Thanks,
Chip
Mozes
Israel
VW Bora
kinda sux to see there's not one in Israel.
how much would this cost? maybe ill be the first...
YEAAAAH
USA
NONE
HEX-CAN-USB
TDIclub Handle: 1963gp
Allen Bristow
270 Longwood Drive
Stafford Virginia, 22556
540-287-4060
phlfly
Banned
N.VA
Passat SEL
Type of VAG-COM available : HEX-USB+CAN Interface
Zip Code: 20176 Leesburg VA
email and ph number per request.
Shaggy
Los Banos, CA
2003 GLS Jetta sedan
I've got the Ross-Tech key-usb and laptop running Vag-Com, I'm willing to help folks out with scanning, adapting, clearing codes, etc. I live in Los Banos, CA and work in Sunnyvale, CA.
torqueit
Rochester, MI
2013 Passat TDI SE
USB-HEX-CAN
Rochester Hills MI but I work in Warren.
Willing to help troubleshoot but my skills are "developing".
PM if interested.
nayr
Colorado
2014 Audi Q7
VCDS Pro Kit - HEX+CAN w/2x2 Adapter
Denver Metro (80044)
PM me to arrange use, german beer required for me to perform alterations.
