When I run group 11 of the VCDS showing boost pressure the actual pressure does not follow the specified pressure closely. The actual pressure lags the specified pressure and the actual pressure is either 20% or so higher or lower. From reading other posts, I think these should match better.
If I perform a basic N75 test using the VCDs I do not see the VNT actuator move.
If I manually exercise the VNT actuator with the engine off, the VNT actuator moves smoothly and freely.
I think this means the N75 valve is malfunctioning.
Any thoughts on N75 being bad?
