amstel78
- Joined
- Jan 24, 2012
- Location
- Shohola, PA
- TDI
- 2012 Golf TDI [buyback completed 14/1/2017] 2006 S65 AMG
A few weeks ago, I performed the code modification for blinking brake lights and hazard lights when ABS kicks on. I finally got around to testing it this afternoon and it didn't work. I have an icy road in front of my house and figured that's the best place to see if the coding change did what it was supposed to. I asked my wife to stand behind the car while I drove it a few feet away and hit the brakes hard. ABS kicked on due to the ice but my wife said that the brake lights and hazard lights did not flash like I thought they would.
Does the car have to be going above a certain speed and have the ABS activate before the brake lights and hazard lights flash? When performing the test I described above, I was going less than 10 mph.
Here's a screenshot of how I have byte 16 in VCDS coded. Everything looks correct as far as I can tell. Furthermore, other subtle coding changes like comfort turn signal blinker count (changed to 5) as well as fog lights on with brights work.
Thoughts?
P.S. Bit 0 above is not checked although comfort turn signal blinking does work on my car. Is that bit unnecessary since the option to activate/deactive this function is already user-adjustable in the MFD?
Thoughts?
