UNOFFICIAL Adblue Heater Element Failure Thread
Yankinwaoz
San Diego, CA
2012 Passat SE
VW replaced my AdBlue heating element under warranty for free. My car has 110323 miles, and is from 2012. So it cost me nothing. I am very pleased with their response.
The dealer did this in one day. I dropped it off Tuesday morning and it was ready Tuesday afternoon.
The repair paperwork says "Found 1 DTC for Adblue tank heater element control circuit low. Checked wiring and connections. No problems found. Per tech bulletin #26-16-05 replaced AdBLue header element. Performed leak test and reset ECM."
Mark_J
Deer Park, Washington
2015 TDI Passat SEL Premium, 2017 Fiat Spider, 2017 Ford F350 6.7 Diesel crew cab PU, 2016 Harley Trike, 2016 Tesla Model X P90D (I know went to the dark side)
2013 Passat SEL Premium, 46,000 milesgot the CEL light yesterday. Cleared it for giggles. Chatted with VW and mine is covered under the extended warranty. So if it comes back will book and appointment.
1 Fault Found:
9656 - Control Circuit for Reductant Tank Heating
P202B 00 [237] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 75253 km
Date: 2017.02.22
Time: 04:56:42
Engine speed: 1483.50 /min
Normed load value: 71.0 %
Vehicle speed: 78 km/h
Coolant temperature: 44 °C
Intake air temperature: 28 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 14.120 V
Unlearning counter according OBD: 40
Outside air temperature: 1.0 °C
Exhaust gas temperature sensor 4: 285.6 °C
Sensor for reducing agent tank temperature: temperature: 4.8 °C
Heat circuit 2 for reduc. agent meter. system: act. voltage: 136.6 mV
Heat circuit 1 for reduc. agent meter. system: act. voltage: 586.2 mV
rustycat
seattle
2015 passat sel
51K on my Nov 2013 SEL and just had the repair done. I had a great experience with the dealer and for that reason I'll give that dealership a high recommendation. The Dealer is VW of Olympia. BTW, I've tried 4 other dealers in the Seattle area and could not recommend any of them.
Mark_J
Wish VW of Olympia was closer. I live in Deer Park Wa, N of Spokane but work in NW Wa. so I am close to the Canadian border.
Fastbird
Fort Wayne, IN
2012 Passat SEL, 2015 Sportwagen SEL (Sold)
Just had my throw a P202B code yesterday morning.
2012 SEL
115xxx miles
If it pops again I'll get it to the dealer for the fix.
shak911
toronto
2004 Jetta TDI-372000KM
2012 SEL
115xxx miles
You're very close to the expiry mileage of the extended warranty of 120,000. miles.
my code (p202 would return 2 restart after reset.)
Fastbird
Fort Wayne, IN
Just got a P202A this morning leaving work. 1166xx miles this time. Making an appointment ASAP.
Rico567
Central IL
By all means get in to the dealer and get the code documented. Even if the code goes away before you get there, at least there'll be a record of it and I'd think you'll have a good shot at a free repair even if you go over 120K.
Fastbird
Fort Wayne, IN
Sitting at the dealer right now. Already have a positive diagnosis, appointment for next Wednesday to have the repair kit installed. They're even washing my car for me right now.
TDIpstick
Florida
02 jetta ALH "upgraded" to 12 Passat CKRA
Waiting to pass "go" and collect my $21k
2012 Passat
CEL
79,839 miles
3 Faults Found:
9688 - Reductant Tank Temperature Sensor
9687 - Reductant Tank Temperature Sensor
15733 - SCR NOx Catalyst Bank 1
no symptoms, no repairs yet, going to see if dealer will fix it under warranty, no risk of freezing in FL
Tinkertoy
Florida
'17 passat SEL 1.8t gasser, '13 passat se dsg
my pump crapping out was part of the reason i took the buyback offer. i backed in to something that must have jarred the pump, I was getting a temp out of range or low pressure code (I forgot what is was exactly). it was not covered under warranty.
that repair, along with the timing belt, tires, brakes, deductible for bodywork, etc would have hurt bad.
I applied the restitution money towards a new SEL gasser, which I love.
roni024
Syracuse, NY
2015 Passat TDI SEL DSG
My MIL on my 13 DSG SE lit up over the weekend. Scanned with VCDS and found code P202A: Reductant Tank Heater Control Circuit. Car has roughly 135k on it, so warranty coverage is not expected.
I have suspicion that the failure is most likely caused by crystallized urea building up somewhere on the AdBlue heating element, level sensors, or inside the pump itself. I'm planning to attempt repair to see if I can dissolve these crystals and restore functionality. My plan is to siphon and remove as much DEF fluid as possible from the tank, then fill to brim with heated (maybe boiled) distilled water with some isopropyl alcohol added in (say 1/2 cup alcohol to gallon of water). I'll immediately take the car on a little roadtrip (1-2 hours highway driving), then empty the water and refill with DEF.
Has anyone tried something similar and can report your findings? What are the risks involved with running the car with water instead of DEF for a short time?
redline_r
Atlanta, GA
12 Touareg
Did you do this?
I'm so curious as to what's causing this part to malfunction all the time, and haven't found that explained anywhere yet.
bustNfuel
Raleigh, NC
Sold: 13 Passat SEL TDI
AdBlue heater replaced under TSB 2041110 after CEL. Codes P205B and P20EE.
Free DEF fill.
Drive more, worry less!
jafische
Pace, FL
2013 (A3) TDI SEL Premium (Reflex Silver / Moonrock)
Did you ever get an answer to this?
I tried wiring in the resistor by cutting off the black and white wires and looping it back to the car but my car keeps throwing the P202B fault after 2 drive cycles. In the photos provided in the original post it looks like there are 2 resistors wired in.
Can anyone clarify this? I've already dropped my DEF tank 2 times to try this fix.
The 202B is the heater control circuit.
The 205B is the Temperature Sensor Circuit Range/Performance.
I wonder if you would have wired a 3ohm resistor to the red/white (heater), that is that where you needed to trick the car?
enpassat
Northern California
2014 Passat
2014 Passat TDI SEL
57246 miles
CEL with a P205B
CEL would come on (sometimes) when the vehicle was cold and RPMs went over 2000. I live on a hill, so while coming down in the the morning it would often downshift and the CEL would (about half the time) come on. No drivability issues, just an annoying light. If cleared, it would stay off until the next cold start. If I could keep the RPMs under 2000 while the engine warmed, no CEL.
P205B on my scanner read: "Reductant Tank Temperature Sensor, Circuit Implausible Signal" and shows the vehicle speed was 158 mph.
I swear, officer, I couldn't have been going over 120.
VW dealer found an "an open circuit in tank temp sensor", then drained the ad blue tank and replaced heater element and all gaskets and seals and reinstalled tank and topped off.
All under warranty, but for me it ends June 2024 or at 120,000 miles. Gotta do some roadtripping I guess.
Thanks to all who post on this forum. This is my first TDI and so it's great to be able to access the repository of knowledge and experience that's here.
jafische
Pace, FL
2014 Passat TDI SEL
57246 miles
CEL with a P205B
Install external thermistor unless you live in Canada. I have a 2013 and have been through 4 adblue tanks under VW warranties.
Lex Tdi
Lexington ky
2013 Passat
Good grief... there is a good way to be done with all that;). The past 100k trouble free miles have been amazing!
Windkid
Ogden Utah
Did this work?
Tom in PT
Twilight Zone, WA State
Thanks for posting that! I have not had this code (yet) but I may just take it apart like he shows just to clean it and keep it happy. Gotta love those "special VW tools."
vwp13tdi
Adrian MI
Passat SEL (Highline)
Would that external thermistor work if I live in Michigan? I am assuming you are referring to Canada because of the cold weather. Michigan is not as cold but it gets cold sometimes. So, would that work or will I be better with the heater replaced? Thanks for any information you could provide.
jafische
Pace, FL
Do you have a heater failure or a temperature sensor failure?
If it's the heater, I wouldn't risk freezing the tank. Change it out yourself. It's pretty easy. My wife and I did it in ~45 minutes.
If it's just that pesky temperature sensor...
The theory of the thermistor is that is measures the temperature (of the adblue) and it is submerged. Theory me is, if I were to remove the thermistor from that liquid to stop the failures, I am dry.
Now if DEF freezes at 12°F and my dry thermistor senses the temperature is 30°F (someone fact check that trigger point) the adblue heater turns on to stop the tank from freezing.
In Florida, we may have seen 12°F for a few minutes before we all froze to death. We don't care about the actual heater, just the temp sensor because of the check engine light will drive you crazy.
vwp13tdi
Adrian MI
Thank you for your reply. I have P205B trouble code. When I googled it: problem with the reductant tank temperature sensor. It says nothing about the heater. Does that mean that during the winter the heater will turn on? My concern is if the heater never turns thinking it's warm enough, because of the faulty sensor. I understand from your reply that I should just replace the heater regardless (assuming the heater comes with the sensor). Please confirm. Any idea about the cost of the heater and where to get it from? (I hear dealerships are having backlogs for the heater because it is made in Ukraine). Thank you again.
jafische
Pace, FL
DROK 10K Temperature Sensor Probe, 5pcs 1 Meter Waterproof Temp Sensor Probe, Stainless Steel 3950 NTC Temp Sensor Probe, Digital Temperature Transmitter Extension Cable https://a.co/d/a1GEx0m
I replaced my temperature sensor with this. Externally. Drop the tank. Cut the wires. Ran this up to the trunk.
$10. Less than an hour.
jafische
Pace, FL
Unfortunately I did not take good pictures when I change mine out so I forget the color of the wires to tie this into.
Just make sure you don't cut the wrong side of the harness and cut the temperature sensor wires leading into the tank. So you have two temperature sensors tied together.
vwp13tdi
Adrian MI
I need to open the tank and pull the sensor, right? Then cut the faulty sensor and replace with the 10K temperature sensor probe. Is there a youtube video or something similar?
jafische
Pace, FL
That will help
Even better;
Jcristto
California
Golf BEW 5spd, Touareg Executive CNRB
So the SS end sits directly in the heater/pump?? Or just in the tank/ as long as it’s submerged???
