Could a TDI be used in this same situation but in a smaller pickup like maybe a Ranger or Tacoma??
I went to the track this past weekend to get out of the house and see my cousin race his bike, but between events there was an electric motorcycle class that ran on the track and after watching the race i went to check out the the bikes and ran across a really nifty setup for a DIESEL that blew my mind...
This guy took a 2008 Dodge Ram 2500 6.7L Diesel pickup and took the drive shaft out of the truck and installed an Electric Motor coupled to the output of the Manual Transmission and another coupled to the Rearend of the truck.. Between the frame he had an aluminum box containing the batteries, which he claimed he could get 41 miles of range out of before they were dead...and their voltage matched the voltage of his bike... so between races instead of towing a electric generator to site, he idles his truck in 6th gear, thus turning the electric motor creating power to charge the batteries and such.. the battery bank is the same voltage as his bike battery setup, so he just connects a thick wire between the bike and his truck and the trucks full batteries dumps their charge into the depleted bike battery via DC to DC charging.. within a few minutes.. He leaves his truck idling between races to top off the charge on his trucks batteries via the electric motor powered by the diesel generator.. When the truck is idling around 800rpms.. connecting the bike to the truck makes the turbo spool up at 800rpms from the load of the electric motor.. making turbo noise out the exhaust..
He said he drives the truck to and from work during the week now all on EV since its within the 41 mile range, he also told me that on the highway he can pull off 26mpg with the truck due to the low rpms of the motor and constant load...He has solar electric at his house and he wired up his batteries to a separate plug that matches the voltage of his truck bank also so he can charge it DC to DC to negate the loss from equipment and allow his truck to be an extension to his house backup power...
He uses the truck to tow the bike to the track in the back of the truck.. so the electric motors seem to be strong enough to tow a few hundred pounds over the weight of the truck.. he said the back one was 450 torque and the front one was 280 torque
So this guy is getting better than stock MPG with the truck when using diesel.. saving money
Saving the cost of 41 miles a day in fuel to drive the truck...saving money
Saving the cost of owning and running a secondary electric generator at the track... saving money
Saving the cost of electric to power his house and truck, by having solar panels and solar bank at home.. saving money..
This idea just seems to be a win-win from all directions.. why don't car and truck manufactures not utilize this type of setup in current vehicles??
(Image is not the truck, but similar model... i was so in the moment talking to the guy i totally forgot to take a picture of it)
