UPDATE 2/9 at night I did what JETaah said and messed with the break booster vac line nipple once I had the gauge on it. It started at 25 inches when I put a little bit of pressure on the nipple and break booster line it went down to 20inches and started shaking up and down 2-4 inches!
Do I need to replace the whole line? Is it just plug and play?
Thanks for the help guys.
Update 2/9 I replaced the n75 valve. It seemed to help a little bit. But im still having trouble getting boost to spool up fast and it seems to die off at high rpms.
Here is my recent turbo log. https://drive.google.com/file/d/0B55tRF16hTrUTE9lQ3BIWm5TZGM/view?usp=sharing
It is having trouble staying at the desired boost as you can see.
My boost gauge is also shaking which it has never done before. Here is a video of it shaking https://www.youtube.com/watch?v=nwk6Vk-FtZc
Do I have a leak in my inter cooler or exhaust?
What else could be wrong that could cause this?
Update 2/3. The N75 to my turbo is only getting 17 inches and the needle is moving a little bit up and down. Here is the video https://www.youtube.com/watch?v=eQszt5MSbe4
Is my N75 dead or is there a leak? Im getting 25 inches from my break booster.
I took my boost valve off too after noticing that it was letting vacuum out where it should be a one way valve but I might be wrong there. https://www.youtube.com/watch?v=fKCAaTEVqD8
Any advice is appreciated thank you guys
op
I've been having some low power and turbo lag in my 03 alh tdi jetta recently. It happened out of the blue one day when I was taking a trip. It seems like my car is just having trouble keeping the boost up and it almost feels like I'm missing a cylinder. Some friends say its running rougher but I can't tell any difference.
But it starts up and idles and runs fine except when I try to get the boost up. My boost gauge needle is very shaky and shakes +- 2 psi when I get on the throttle. I've checked all my vacuum lines and replaced a few that were frayed. I checked my maf and looked at all the inter cooler pipes for leaks.
My turbo only has 30k miles on it. And it has been running pretty good up till this happened.
op
