9755
Yesterday the family and i drove from the East side of Michigan to the west side by grand rapids. In 5th with cruise on the whole way. Got off and was very hard to change gears. Went to leave last night and it acted like I had the breaks on and bogged down and stalled. Then noticed it did that in every gear. It also tries to move in neutral. I changed trans fluid and it had barely in it. End result is the same. Am I right to assume the trans is junk?
There's also no gear grind. Clutch disengages fine. It will stop rolling in any gear with the clutch in. Like the brake is on. The clutch, flywheel, tb, pivot ball, and shift fork all have roughly 20k on them
