MAXRPM
I got (18MM Socket), 2 bolts mount to bracket, and (16mm Socket) 2 bolts bracket to tranny, are they the same like for the TB side, I believe 18mm bolts are 74Lbs, and 16mm Socket bolt are 33 plus 1/4 turn?
From the timing belt PDF (page 8) the 16mm bolts are 30ft lbs + 1/4 turn, the 18mm bolts were 44 + 1/4 turn. They are essentially the same as the trans side.Thxs for the reply but on the timing belt side the 18mm Socket bolt, there is no more 1/4 inch turn it is straight 74 ft lbs tq... it used to be 33 plus 1/4 turn if I'm not mistaken
