COCOLOCO said:
In towing a VW TDI I have a couple questions
Are to leave the key in the on position?
Are to to do anything with a fuse? Can anyone help?
__. Assuming that you mean "towing 4-down", the best way is to use your "valet" key. Put it in the ignition lock and turn the lock so that the steering is unlocked. Then use your remote key to lock the doors. If the key is turned too far, the Daytime Running Lights will be on -- you don't want this so be sure that the key is only turned to the "first click". Also, assure that the ignition is not turned on (also taken care of by "first click"). On first-click, no electrical parts will be energized so there's no need to worry about fuses. Of course, items (like parking lights) that can be switched on without the key on should be off (unless you have a reason to want them on).
__. Of course, the parking brake must be off (ever see a pair of "flatspotted" tires?) and the transmission in neutral. I'd also use a "bra" to stop road debris thrown up by the towing vehicle from damaging the front of the car; also, use a windshield cover which can be affixed to the wiper spindles and the upper part of the windshield.
__. I've often seen advice to make up a check-list to assure that all the correct steps to secure the tow bar are taken and the car is ready to be towed. I think that's good advice, it's a fairly involved process and you want to make sure that it's done right.
