Friend of mine helped me install custom hitch on my 2014 mk6 golf, and we proceeded to install wiring using converter. we made a mistake taking running lights signal from the wire on taillight. That wire shares a signal stop/tail and it must of screw up BCM or something. Now i did disconnected all of it but 3rd brake light stays on all the time ignition on or off. The brake lights on the sides work fine. VCDS gives me error 03266 control circuit for signal horn, and the horn stoped working.
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
www.Ross-Tech.com
Friday,05,June,2015,10:31:10:25161
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWDM7AJ4EW007138 Mileage: 10090km-6269miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 JT HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 5676
Revision: 12H16--- Serial number:
Coding: 0050078
Shop #: WSC 01357 011 00200
VCID: 062D7A6A71456411543-8053
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 521 3528
Revision: 05652104 Serial number: 00001308021586
Coding: 0000020
VCID: 246900E2E7B9B6012A7-8071
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B400C49220001880C02E792210042B70000
VCID: 7DDF1586E49327C9059-8028
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001019
Coding: 0010002002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 7BDB1B9EF28729F93BD-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AC111709
Coding: 6F180A1A90272AC4008800C17000854448010386534D8560648020200040
VCID: 41A7A976D8EB8329211-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27081 26 0512
Coding: 009795
1 Fault Found:
03266 - Control Circuit for Signal Horn
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Mileage: 10097 km
Time Indication: 0
Date: 2015.06.05
Time: 00:32:23
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R02HDXY
Coding: 00004737
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: 3C59D882B709EEC1727-8069
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000081WY00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME2E57647CZZZ7
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME7B28727CZZZ7
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME7C3A337CZZZ5
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME72224229ZZZM
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME2303792FZZZH
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME2803792FZZZN
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440MI6000IH
Coding: 189A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76CD0AAAC9A57491443-8023
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H07 0022
Serial number: 50000000000000716506
Coding: E30000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 973 C HW: 5K0 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 3147F9B6604B13A9D11-8064
1 Fault Found:
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [008] - Performance
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 10093 km
Date: 2015.06.05
Time: 00:00:22
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 080913F1001497
Coding: 350002
VCID: 74C930A2D7D966817A7-8021
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RPATT07
Coding: 0000002
VCID: 7EDD128A29953CD11C3-802B
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF52EDA8D1DA071D0B-803F
1 Fault Found:
13762816 - Databus
U1201 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 10093 km
Date: 2015.06.05
Time: 00:00:22
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665229595
Coding: 010100
VCID: 2B7BEBDE4A677979EBD-807E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 H HW: 5K0 959 701 H
Component: Tuer-SG 009 2105
Coding: 0001204
VCID: 3753C7AE462FCD999F5-8062
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
VCID: 3957C196703BDBE9691-806C
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 H HW: 5K0 959 702 H
Coding: 0001204
VCID: 3851C4924B31C2E196F-806D
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AF HW: 1K0 035 180 AF
Component: Radio Prem-8 H05 0008
Revision: -----09S Serial number: VWZ4Z7N1115833
Coding: 01000400040005
VCID: 64E940E26739F601EA7-8031
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 159
Mileage: 9899 km
Time Indication: 0
Date: 2015.05.31
Time: 17:35:59
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 354FCDA65C233F898D9-8060
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DCAAA41253491843-8063
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007665201289
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A55DE9ABD3DD0F160B-806F
End-------------------------(Elapsed Time: 01:58)--------------------------
I did checked all ground connections.
Thank everyone for your help.
Chester.
www.Ross-Tech.com
Coding: 0050078
Coding: 0000020
Revision: 00H31001
Revision: 00001019
Coding: 0010002002
Revision: AC111709
Coding: 009795
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Mileage: 10097 km
Time Indication: 0
Date: 2015.06.05
Time: 00:32:23
Freeze Frame:
Term 15 On
Voltage: 12.20 V
ON
ON
Term 50 Off
OFF
OFF
Coding: 00004737
Coding: 189A140000
Coding: E30000
Coding: 270F01
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 10093 km
Date: 2015.06.05
Time: 00:00:22
Coding: 350002
Coding: 0000002
Coding: 000000
1 Fault Found:
13762816 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 199
Mileage: 10093 km
Date: 2015.06.05
Time: 00:00:22
Coding: 010100
Coding: 0001204
Revision: 00H22000
Coding: 0001204
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 159
Mileage: 9899 km
Time Indication: 0
Date: 2015.05.31
Time: 17:35:59
Coding: 0001168
Coding: 0001168
ROD: EV_UHVNA.rod
Chester.
