HI,
2 questions, one short one long; I recently did a TB replacement on my TDI PD and found that getting everything apart wasn't too bad but fitting a big Torque wrench into confined spaces to get it all back together was quiet difficult. Also despite purchasing a fairly good wrench I have found that some of the VW values are so low that they are off the scale. So my first question is; are there smaller wrenches around or at least ones that have values at the lower end of the scale?
My second question is concerning leverage and Torque wrenches. I had to do the top mount bearings on my wife's car a couple of months ago, couldn't use the Torque wrench to re-tighten them as you need to hold the centre rod with an allen key, didn't think it was really that important, value is; Stage 1. 60nm, Stage 2. 90 degrees more (per Haynes manual), which is pretty tight if you ask me, so what I did was I tightened them just using a swan neck spanner as best I could . I have discovered since there is a tool called a Crows foot spanner for doing the job but I haven't managed to track one down yet. It's like the head of an open ended spanner with a small bit of the shank at the back and square section hole in it that can take a ratchet/Torque wrench (picture only seen on net). So guess what we broke a bearing last week , one of the new ones, so when I replaced it I thought I better get the Torquing thing right this time. No-one in my immediate area seems to do mechanics tools anymore so I came up with a couple of ideas as to what I could do, the strut top nut is 21mm which is the same as a plug spanner and gives you the extra height you need to clear the mounting plate, it also has a hex section at the top so can be gripped with a spanner, so I thought if I could fit somthing into the other end of the spanner that would take a square section I could use the Torque wrench on there.
Tried it today but it didn't work , Torque wrench was never going to click out and I think the reason is the extra leverage caused by the extra length of the spanner between the nut and wrench. If this is the case though then the Crows foot must suffer from the same difficulty. Having never seen one I don't know if they maybe come with instructions to reduce manufacturers values by a certain amount due to the length of the tool or even if it is possible to calculate a value to reduce the setting by X amount from the additional length....or am I talking crap?
Sorry this is so long but I would appreciate people's views on this, I didn't do any of this stuff at school and I am pretty much self taught a far as mechanics goes so I am learning all the time.
Thanks .
Wallace.
Thanks .
Wallace.
