Jetiwarrior
Just replaced my timing belt in 2003 Jetta and would like to thank this site for excellent vender's and how to instructions. The total job took me 12 hours since this is my first A4 belt change and it was 110 degree's in the shade. I have changed belts on A2 and A3 before but this required a lot more items to remove. The best hint I would give someone who never did one is to study your existing belt real good before you remove it. I got the belt on TDC, installed the camlock and injection pump pin before I removed the old belt. It was easier to also take the injection pump pulley off to see where the pin to lock it goes since I replaced the 3 pump bolts and wanted to see the pin inserted in the correct spot. I used Dieselgeeks water pump removal bolts which made it easier to remove the old pump since it was stuck pretty good. The worst part was removing the motor mount and having to work with it in the way. It would have been nice to totally remove it, change the belt, and then re-install it. The only problem I had was that I installed the mount back first before I put the timing belt covers on. I had 73,000 miles and since the belt was 6 years old I changed it ahead of time. My belt was making the swoosh sound back in Feb. and I decided to replace it now. The 2 small rollers sounded like they were drying out and the belt was showing small cracks on the inside due to its age and from the heat. The water pump also was starting to develop a small leak by the shaft seal. I attached some pictures of the timing marks.
http://img257.imageshack.us/gal.php?g=camshaftlock.jpg
