Yeah please do this. I broke mine when I did my TB. No brakes and no boost until I got anotherAnd disconnect the vacuum 'pipe' coming out of the pump before moving the engine that much or you'll most likely break it.
It won't help you - getting to the bolts is the easy part - getting the mount to fit out between the body and the engine is a whole other issue. Unless you drill one giant hole through the frame, it's not coming out without tilting the engine.im thinking of drilling through the inner wing to get to the bolts that way I wont need to raise or lower it or buy a engine support beam and will save accidently overstretching and damaging any thing else on the car/engine/exhaust.
has anyone done this? your thoughts?
