otm646
I am swapping in an AAZ into my 79 rabbit. The idea came up of using an AHU injection pump to replace the mechanically controlled AAZ pump.
I personally like the charicteristics of a IDI better for a performance application. I am looking to have all the telemetery of the electronically AHU while keeping the performance aspects of an IDI.
The conversion is simple to CE2. I already have an CE2 Golf body harness in hand and a engine harness and computer out of a 98 Jetta on its way.
I would use the IDI injector body from a Mercedes 60X with the built in needle lift sensor.
I also would transfer over the crank and the crank position sensor from one of my spare TDI blocks.
My question comes to ECU tuning. start of injection obviously occurs sooner in an IDI.
Does somone have documentation of the differences between start of injection between an AAZ and a TDI?
The build thread will start soon!
