So my battery kicked the bucket. I know there is a lot of debate on which battery to use mainly due to having enough amp hours...but alas I cant find anything cut and dry for MK6 when I need it!
I'd rather take care of this today, Sunday, so OEM battery at the dealer is out if a suitable sub is available through normal retail stores. With mine done in just under 3 years and many other people posting about the same time frame for their OE battery, I'd rather not use another one unless there is really no other good option for specs and fitment.
That said....seems like group 48 is the size that is supposed to go in, and while easy to find CCA and all higher then OE, AH is not up to par. There is A LOT of mention about H7/94R's exceeding every spec including AH, but since they aren't the exact OE size, I can only find tons of stuff about people raving about how much better they are and how they fit into MK4 ad MK5's.
Will a diehard Gold or Energizer 94R fit into my 2011 Golf? The part store sites say incompatible...but from what I gather, the OE battery is 10.9L x 6.8W X 7.5H, where as those 94R's are 12.4 x 6.8 X 7.5. Looks all the same except for the extra 1.5" length. Will the tray and cover accommodate that? Also, seems like the retainer bracket should not be an issue since the width is the same no?
If not, are there any other G48/H6 size batteries readily available with enough AH?
