Hi everyone,
I've just had a new clutch, dual mass flywheel and second hand gearbox fitted. I've done about 100 miles since it was all fitted and have just noticed this "tinny" ticking noise when the car is hot - haven't noticed it when cold. I've posted a Youtube video of the noise here: https://www.youtube.com/watch?v=4EP3bHHdq80
The sound is engine speed dependent. Sound only changes very slightly when the clutch is pressed in.
Hard to tell if the sound changes in different gears due to road noise.
Removed flywheel inspection cover (as I found a thread on here suggesting it was a common cause) and found it had been rubbing. Removing the cover did not get rid of the sound after I got the car nice and hot. I have also noticed that the metal gasket between the gearbox and engine looks a little beaten up - is it possible that this is rubbing on the flywheel?
No error codes, smoke or performance loss noticed. (Have had a P2108 - Throttle Actuator Control Module error a few times but the noise is coming from the back on the engine and no where near this. Believe it is unrelated).
Any pointers or ideas of things to check would be much appreciated - if not I will be doing a 65 mile drive back to the garage who fitted it all!
Cheers,
Jack
Cheers,
Jack
