Googo
Piezoelectrics can be used to inject the fuel, but as far as how much pressure it can produce, I am not sure. Example - most inkjet printers today use piezoelectric materials compress and squeeze out a drop of ink. But from reading, the new fuel injectors just change the actuation mechanism from a solenoid to a piezoelectric.TDIMeister said:Actually, piezo actuation is not a new third method of Diesel fuel injection beside CR and PD. It is merely a method of actuation that uses special crystals that can expand or "actuate" under a piezoelectric excitation as opposed to electromagnetic solenoids. The technology can be applied equally to PD and CR, i.e. you can have piezo CR or you can have piezo PD. The newest VAG V6 and V8 TDIs are common-rail with piezo-actuated injectors, while the abovesubject 170 HP 4-cyl have piezo-actuated unit injectors.
With either scheme you still need a means of some sort to raise the fuel pressure. Piezo technology does not do away with the plunger pump in PD systems or the rotary-piston pump used in CR systems. It is merely a system of controling the injection event by controlling needle lift or fuel pressure in the injector by actuating a spill-valve. It's chief benefit over solenoid actuation is that it can actuate one or more orders of magnitude quicker for better and more rapid control of the injection event. That's all. There's nothing magic about it.
