Stutter When Accelerating
bjmarler
Tullahoma, TN
Jetta GLS, 2004, White
For just the last few days, my 2004 Jetta TDI will stutter mildly when I'm accelerating such as to pass a car. If I accelerate slowly, or normally it does not stutter.
Any suggestions where to start looking for the cause?
Brian
bjmarler
Tullahoma, TN
Fyi, one more symptom. The car normally will keep pulling hard up to 4K, but now it starts tapering off at 3K and totally quits pulling at 3.5K.
JB05
Il.USA
Golf,2005,anthracite blue
Have you ever had the in-tank lift pump replaced? Got any CEL or hidden DTC's?
bjmarler
Tullahoma, TN
Thanks for the fast reply. Nope, never replaced the lift pump, and I have no CEL. The car starts fine and as long as I drive it easy, it behaves and accelerates fine
30_Yr_Dsl_Veteran
banned Ric Woodruff alias account and troll
Lake Placid, FL
2009 Jetta
Why are you at such high RPMs in the 1st place???!!!
There are gobs of torque at low, low RPMs. I used to upshift with my '98 Jetta TDI at 1,800 RPM. With our '09 Jetta TDI, I upshift at 1,700 RPM into every next gear.
bjmarler
Tullahoma, TN
After driving it more today I would have to say that it feels more like the turbo surging when under heavy acceleration, trying to boost then stopping. No odd noises at all.
bjmarler
Tullahoma, TN
Here's one more piece of the puzzle. I let the car sit for several hours and get cold. When I drove it home it did not do the stuttering at all. It pulled easy up to 4K.
So, it only seems to do the "stuttering under acceleration" and having limited total acceleration to just over 3K, only once it's warmed up.
Does that make any sense?
Dimitri16V
DE
01 Golf, 04 Golf
going thru the same issue right now
Fuel filter , my in tank pump is new
Dimitri16V
DE
01 Golf, 04 Golf
fuel filter and setting cam timing from 2.9 to 0 settled it for me
Nice to have the power back
bjmarler
Tullahoma, TN
Sorry this took so long to update. It was my fuel filter. It was almost completely clogged. I must have gotten some really bad diesel somewhere. I do remember several months before this started, being at a station and the pump took FOREVER to fill up my car. Their tanks must have been REALLY low and sucking up all the crap from the bottom.
After changing the fuel filter it no longer hesitates, and pulls hard all the way to 4K like it normally did.
So, lesson learned. If I stop to get fuel and it pumps really slow, .. STOP immediately and go somewhere else.
