rattlenbang
Hey all, Ive got a 2002 with 360k km that started giving starting problems a few months ago, getting progressively worse. It doesn't seem to matter of its warm or cold, maybe more often cold, but there's times when it starts right up, other times when it won't or I have to crank and crank to get it to go. It's not glowplugs because those check ok and no engine code comes up. They're also getting voltage, as is the cutoff solenoid. I've checked and fuel is getting to the injectors when cranking, and the air valve in the intake is wide open.
The engine never dies once started, just hard to start sometimes.
It has a new battery and seems to be spinning the engine over quick enough.
I wondered about compression, but it runs great, no smoke, and most times it lights up immediately even when stone cold. You can then start it, run it for 20 min, shut it off, then it won't start again.
I've dealt with bad glowplugs and bad cutoff solenoids before, but this is strange in that it's only starting causing the problem but it's not those components. A weak battery can cause difficulty starting but that's not it. If it was a worn engine it should always be hard to start. If there was something in the injection pump or fuel supply it should affect running performance. Weak starter should be obvious as slow cranking. I'm getting stumped with this one. My son opened up the injection pump to replace a seal awhile back which might have done something, but hard to see what.
Any ideas?
Any ideas?
