jesus_man
- Joined
- Nov 9, 2005
- Location
- PNW
- TDI
- 2005 Jetta (gone), 2002 Passat (gone), 2009 JSW (VW bought), 2010 JSW
It seems my problem surfaced after I installed the P2015 Code Repair Bracket from dieselgeek. But we've also moved to a new climate and driving style has changed a bit due to driving in different neighborhoods.
As I am cruising out of my neighborhood with 15, 20 & 30mph speed limits the car will hesitate, stumble briefly, or change speeds give or take a mph or two. It doesn't seem to die out, but it's just enough to feel the car lose power and slow before it goes back to normal. There are times I can get it to do this for 10-15 seconds if I hold the same speed. It smooths out if I accelerate or lift off the throttle. It also seems to correct itself if the transmission shifts to the next higher gear.
Oddly enough, I just performed my second DSG fluid change a few weeks ago and the problem seemed to have gotten better and the transmission behaved better. But the car seems to have gone back to it's old ways. Let me explain this behavior as I fear they may be related. The transmission seems to have a lot of slack between stop and go. I've adjusted my driving style to accommodate it, but if I come to a stop and then go, I have to ease into the power or the car will jolt to moving forward. The same thing happens if I am coasting and then accelerate. It's almost as if the CV half shafts can turn 180* before they catch. I have checked my CVs and they are fine, but if you imagine the feeling that would cause...
Here's my theory and I hope you can prove me wrong. I am afraid the transmission is on it's way out and the stumble I feel is the transmission wanting to shift gears, so it sends it's signal to the engine, but then redacts that request and stays in the same gear. Meanwhile the engine cuts power to prepare for said shift, which then didn't happen so it resumes.
Another odd engine stumble happened yesterday at 70mph, which it's never done. Happened twice on the same commute, but hasn't happened since. And in fact, the car today runs and shifts like a car with 145k should.
I am not getting any codes. I have run the ross-tech report, but I didn't get a chance to look thru it in detail. I am confident it is not water in the intercooler as I have a drain valve hooked up to that which is very slightly open and drains each time the turbo creates boost.
So what else? Could it be that the valve the dieselgeek bracket is on is hunting for a happy spot and it can't get back to where it was used to going?
Thanks for the help! I want to get a Malone Stage 0.5, but I can't justify it with the car doing what it is right now.
