RoundHouse
- Joined
- May 23, 2001
- Location
- Ga USA
alright, gonna try to 'splain this the best I can
00 Beetle, wouldnt start, engine would spin over, but not start,
checked around, the selenoid on the injection pump had low voltage, ~7 volts.
I run jumper wire from battery to selenoid and engine will crank
I find fuse in box thats hot on crank and run and run jumper wire from there to selenoid.
engine runs but no power, turbo not spooling up.
also when you cut engine off the "brake" light stays on, something beeps, and the airbag light flickers. unless you put it in reverse before you cut it off, then that doesnt happen.
Im guessing there is a problem with power coming from some relay that powers the selenoid, but looked at a couple of diagrams and have not been able to make heads or tails of it.
