Our A4 Golf is running great, except it is starting to have problems with the ignition switch.
At first it just didn't recognize when the key was pulled out (didn't turn off radio or pop the door locks). But if you whacked it or put the key back in and out that usually fixed it. Now it has gotten to the point where no amount of fiddling will get it to recognize that the key has been removed. And a couple of times the key doesn't unlock the tumblers.
My original theory was the switch mechanism that senses the key being there just got dirty. So I tried some WD40 in the tumbler. That did not really do much. Might still be dirt, but there would appear to be too much to wash away with some spray.
Any suggestions as to what this might be, and what needs cleaning/replacing to fix it?
And any guidance on how to remove the cowling around the ign switch to get to the innards?
TIA
TIA
