Steering Wheel Swap issues
jramsay
Southwest, Florida
2015 Jetta TDI
I just switched my steering wheel to one with paddles. The thing is the steering wheel also has the capabilities for Active Cruise Control, which my car does not have. It does have some other codes, and the Steering Wheel Module on VCDS won't open. Currently, everything works except for the Cruise Control, and the glow plug light is flashing. Currently, no other trouble lights are on, and the car is driving fine. The other thing is the fuel mileage is reading low, which I am assuming is due to the ecu error (flashing glow plug light). I am trying to see, if there is a way in VCDS to fix this issue. Below is what I am getting with Autoscan.
Wednesday,10,May,2023,20:34:47:58437
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: 3VWLA7AJXFM339717 License Plate:
Address 01: Engine (04L 997 016 E)
20:34:35
IDE00021 Engine RPM 1165 /min
IDE00100 Engine torque 30.9 Nm
IDE00350 Air mass: specified value 250.0 mg/stroke
IDE00472 Mean injection quantity 3.91 mg/stroke
IDE04002 Charge air pressure control BP_A cmd/act:104.7/105.8 kPa
IDE07712 Turbocharger 1 turbine input: temp. sensor 1: B1: raw value 247.0 ∞C
IDE07818 Fuel high pressure sensor: actual value 380800 hPa
IDE07820 Fuel high pressure sensor: nominal value 392300 hPa
Thursday,11,January,2024,16:43:39:58437
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VCDS Release 23.11.0: Generic OBD2
Mode 1:Read Data
70:Boost Press Ctrl A/B BP_A cmd/act:95.9/100.1 kPa
71:Var. Geom. Turb. Ctrl A/B VGT_A cmd/act:100.0/99.6 % VGT_B cmd/act:---/--- % VGT_A:Closed Loop
Thursday,11,January,2024,17:01:51:58437
www.Ross-Tech.com
Address 01: Engine Labels: 04L-907-309-V1.clb
Control Module Part Number: 04L 997 016 E HW: 04L 907 309 K
Component and/or Version: R4 2.0l TDI X20 9465
Software Coding: 011D0012042410084000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM20TDI01104L997016E 004002 (VW36)
ROD: EV_ECM20TDI01104L997016E.rod
VCID: 353733DC05CF32F2CC5-8060
1 Fault Found:
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [10101111] - -
[Checking coding/versions ofcontrol modules in drivetrain]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 242326 km
Date: 2024.01.11
Time: 01:36:32
Engine RPM: 2151.00 /min
Normed load value: 1.2 %
Vehicle speed: 30 km/h
Coolant temperature: 92 ∞C
Intake air temperature: 82 ∞C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.140 V
Unlearning counter according OBD: 40
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: -0.742 m/s≤
Readiness: 0 0 0 0 1
Address 01: DTCs cleared
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BS HW: 1K0 907 379 BS
Component and/or Version: ESP MK60EC1 H46 0166
Software Coding: A14B400C49250003851202E592200042A1100012
Work Shop Code: WSC 00066 000 00000
VCID: 04519E181E155B7A0BB-8050
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 91
Mileage: 242321 km
Time Indication: 0
Date: 2018.06.03
Time: 01:29:60
Freeze Frame:
Count: 2
Count: 14
Count: 29184
Count: 16390
Count: 51200
Count: 0
Count: 1277
Count: 0
Address 03: DTCs cleared
Address 56: DTCs cleared
jramsay
Southwest, Florida
2015 Jetta TDI
I am still looking on getting help on this situation. The steering wheel I have with the paddles, looks like the TDI wheel. When it comes to the differences, it has the ACC button where my old wheel is blank. Here is an image of the new wheel: Steering Wheel Image
lemoncurd
Eastern CT
2013 CJAA GTB2266
that is not a complete autoscan.
please post 2 autoscans using the code function, one scan with the old wheel, and another scan with the new wheel.
you should be able to just copy the coding from the old wheel to the new one, which would nullify the ACC button until you code it back on when the rest of the retrofit is complete.
this error tells you the new wheel isnt coded correctly compared to the other modules in the vehicle (ECU, ABS, etc):
Nuje
Island near Vancouver
ACC buttons won't work with "normal" cruise control. With both wheels off, it's pretty easy to swap buttons from one steering wheel to the other one. Three T10 (or maybe T8?) screws and they pop right off. I'd probably move both (left and right) over (along with the ribbon cable between them) just to keep as much the same as possible between the steering wheels.
Cuzoe
Los Angeles
MK7 Golf S
From personal experience, glow plug, light and ECU error are exactly what happens when you have the wrong cruise control buttons.
Cuzoe
Los Angeles
MK7 Golf S
Yes that is pretty much what happens to me. The glow plug sign starts flashing, and my mpg plummets.
I don't remember it having any effect on the cars calculated mpg. I also didn't drive with the error for more than a couple days. I'm not sure why it would affect MPG though, there's not a mechanical problem. It's just incorrect coding, it's not even really an electrical problem.
jramsay
Southwest, Florida
2015 Jetta TDI
Yeah I am just trying to figure out how to recode it, so that the code will go away. I noticed that 16 - Steering Wheel is not available when I use VCDS.
jramsay
Southwest, Florida
2015 Jetta TDI
I tried to switch them over, but the assembly (from old wheel) is too big for the slot on the new wheel.
Cuzoe
Los Angeles
MK7 Golf S
Do you have a full scan? I've never run VCDS with the steering wheel removed but module 16 is actually the clockspring which doesn't have to come off to replace the steering wheel. If you only replaced the steering wheel with one that has paddles the only thing that needs VCDS (or OBD11) is an adaptation in Module 19 gateway that says something about tiptronic switches installed. Lots of cars, already have this set to active because there's no negative to having it set.
I'm confused about this. If the wheels are the same shape the buttons should swap over. There's only the Golf/Standard wheel and the GTI/R version (round airbag).
Nuje
I think both @Cuzoe and I (at least I was) are/were assuming you're on a Mk7 car, but your info says 2015 Jetta, so....that's a Mk6 (?).
In which case....I don't have a lot to offer; no experience with those steering wheels.
Maybe post photos of what you have and what you want to install, and we can take a swing (?)
Nuje
Those look exactly like the Mk7 steering wheels, in which case you should be able to swap the buttons from your current wheel to the new one, and have cruise control working.
jramsay
Southwest, Florida
2015 Jetta TDI
Yeah with my stock one I can see the 16 - Steering Wheel on VCDS, but don't see it with the new one connected. So I don't know how to code out the adaptive cruise control, to the regular cruise control to what I have in my car. This is the main problem I am seeing.
Nuje
In that case, sounds like you've got incompatible steering wheels. I just went through the same thing with changing buttons on my Mk8 steering wheel.
Your new one has an unusual airbag retention system as well (all of my Mk7 and Mk8 wheels have had two "hooks" that catch wire "spring" arms - yours has three spring-loaded posts, it looks like(?)). And this one has heat (connector with red lock-tab). Does your clockspring have the connector for heat?
What part number is on that steering wheel? Is it similar to your original? Like, do the first three characters have the same letter? Like both are 5Gx or 5Qx, or 1Kx, 5Kx. If you've got something with a K - that's 6th gen stuff; the G and Q are more typically the MQB (mk7 and later). And what about your clockspring - what's the letter in its first triplet of the part number?
If they don't align. you have two quite different parts trying to talk to each other.
In any event, like I mentioned above, you're playing in Mk6-land (even though the wheels LOOK a lot like the stock Mk7)...and thus, way outside my knowledge / comfort zone. Google about, my friend. Try Vortex, golfmk6.com, or even here in the Mk6 sub-forum (although i don't recall seeing a etc - see if any of those folks have something similar.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
You might needs to swap the steering wheel control module, I had to do it for my brothers 06 Jetta TDI to have Multi function steering wheel controls to work.
