studebaker
Starts up, shuts off ( immobilizer issue )
I have been reading thru the forums for this issue we have on our 2006 Jetta TDI. 5sp and 150,000 miles. Doesn't show any codes.
The first time this happened was a couple of weeks ago. Wife drove it to work just fine. Got in at the end of the day to come home and it would start up and run a couple of seconds then shut off every time the key was turned to start.
I trailered it home and it started right up and ran fine for me to unload it off the trailer and put in the garage. I changed the 460 relay just in case. Drove it into town yesterday and all was fine. Went to start it this morning and same issue - starts up fine, runs a couple of seconds and shuts off.
Where do I trouble shoot next?
Thanks!!
UPDATE--- just found this in the "sticky" section
http://forums.tdiclub.com/showpost.php?p=1972387&postcount=8
I tried the spare key and the car runs just fine. Changed back to the main key and same old issue. So the key seems to be the problem. Thanks for that sticky info!!
**very strange to me, in looking closely at the main key, I can see no discernible wear. The battery also checks at as good.
OK, so everything points to the immobilizer program chip in the main key.
Thanks!!
