SilverGhost
- Joined
- Mar 25, 2005
- Location
- Back in So Flo - St Lucie
- TDI
- '05 Golf - totaled :(, wife's '13 Beetle - buy back, TDIless
I was cruising around ElsaWeb a little bit ago and cam across this, thoughts?;
Link me (sorry, I guess you have to log in to see the original)
Bio-diesel
Only vehicles manufactured in series, or with the special equipment (number PR 2G0) approved by Volkswagen for use of bio-diesel, can use bio-diesel.
The Golf diesel engines are able to run with bio-diesel as standard.
Caution
-If bio-diesel is used without the vehicle being prepared for this, it may damage the supply system.
-When fuelling with bio-diesel, always use it in compliance with the rule DIN EN 14214 (FAME)!
-The use of bio-diesel that does not correspond to this rule may clog the fuel filter.
The bio-diesel must comply with the rule DIN EN 14214 (FAME).
-Bio-diesel means “methyl ester produced from vegetable oils”.
-DIN means “Deutsches Institut für Normung e.V (German Institute for Normalization)”.
-EN means “European Norm”.
-FAME means “Fatty Acid Methyl Ester”.
Particularities of the bio-diesel
-The vehicle power during the use of bio-diesel may be slightly inferior.
-When bio-diesel, the fuel consumption may be slightly higher.
-Bio-diesel supports temperatures up to 14 °F (-10°C).
-With temperatures lower than 14 °F (-10°C), it is recommended to use a winter fuel.
Note
-When bio-diesel is used, observe the modified intervals to drain water and change the fuel filter.
-When the vehicle is immobilized for periods longer than 2 weeks, it is recommended to replenish it in advance with conventional diesel and travel a distance of approximately 30 miles (50 Km), to avoid damages to the injection system.
