Divakaran
Dear All - hope all should be having great weekends. problem statement is my car is not starting. it had flat battery and was standing for a while on flat battery. I recharged them and connected it back and the car started fine, it was running fine for 15 minutes and then stopped and from then never starts again. i checked the following
1. battery terminal voltage - 12.5 and above and good
2. compression test on cylinder - all ok as per factory manual
3. fuel from tank pressure and flow is ok
4. fuel delivery from electric pump to HPP is good and pressure is perfect as per factory manual
so i suspected the HPP and removed the delivery line of HPP that goes to injection units distribution and found no fuel coming. i though it could be HPP issue and traced all the fuses, cables relays etc both in cabin, in engine comportment, all perfect. however the HPP is not sending fuel. so i removed the N290 fuel dosing (metering device) from the HPP to check the signals, and cranked the car without the metering device connected to HPP, the car started running fine. it run for quite a while and stopped after some time saying the fuel pressure is too high in VCDS. also the vcds is reporting the N290 valve is open circuit because it was not connected. if i connect it back to HPP and the car is not at all starting, it cranks well and the VCDS is not reporting any error in the engine module. below is my scan report. is there any expert advice that i you share to check ? how do i check the metering device whether this is faulty? i do not want to buy a new one to replace them before confirming thats the issue. its very expensive here in India and please help. below is my vcds scan report.
below is the latest scan report
how do i get the freeze frame data using the VCDS?
Saturday,25,September,2021,16:49:53:29955
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: TMBBNC1Z9AA151374 License Plate:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBNC1Z9AA151374 Mileage: 116440km-72352miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CLCA) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 EJ HW: 03L 906 018 BR
Component: R4 2.0l TDI H20 9977
Revision: 42H20--- Serial number: CVN: BA7A8368
Coding: 00110012040500080000
Shop #: WSC 10259 663 00000
ASAM Dataset: EV_ECM20TDI01103L906018EJ 003008
ROD: EV_ECM20TDI01103L906018EJ.rod
VCID: 76B5E25848406D8B8DD-8022
VINID: 91D49279306A2514411410C710D22E088E
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0104
Revision: 00H35001
Coding: 0017665
Shop #: WSC 33361 790 00000
VCID: 7BA3F36C7FE230E3F23-802E
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000001002
Shop #: WSC 73430 790 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 03538B8C0B924823BA3-8056
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 4E180AB8B00508C04008008011000124410000AE422085605C0440000000
VCID: 323D1E48E42831AB615-8066
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 28011 22 0601
Coding: 00D7B7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230110 05 54 0402
Coding: 0730ED
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641000904029
Coding: 100001
VCID: 40D944805A84933BE71-8014
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 07 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06BB8G
Coding: 0012343
VCID: 7DA7FD7461F63ED3CC7-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CP HW: 1K0 953 549 CP
Component: J0527 053 0111
Coding: 0000003
VCID: 025D8E881808412BB15-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Z0 920 803 G HW: 1Z0 920 803 G
Component: KOMBI H06 0305
Serial number: 00000000000000
Coding: 110800
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 38292C6002D4DBFB5F1-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K101270083
Coding: E9A07F06000202001303
VCID: 698FB924057EB27310F-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H06 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8DC6280CF8B96B195-803E
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MAX3.clb
Part No SW: 1T0 959 701 AA HW: 1T0 959 701 AA
Component: Tuer-SG 009 2114
Coding: 0004854
VCID: 76B5E25844C06D8B8DD-8022
1 Fault Found:
00120 - Outside Warning Light/Door exit Light Driver Side
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 68 3001
Revision: 00H17000
VCID: 313F1144ED2E0AB318F-8064
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 116447 km
Time Indication: 0
Date: 2016.02.16
Time: 02:54:01
Freeze Frame:
Battery Volts: 12.1 V
DD
Temperature: 38.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 1T0 959 702 S HW: 1T0 959 702 S
Coding: 0004854
VCID: 48C95CA07EB4AB7B2F1-801C
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 161 F HW: 1Z0 035 161 F
Component: SWING 009 0065
Revision: 0I001001 Serial number: SKZ1Z2K8364845
Coding: 0D0004000001
VCID: 313F1144E12E0AB318F-8064
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 33361 790 1012544
VCID: 323D1E48E82831AB615-8066
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 33331B4C173238A36A3-8066
End----------(Elapsed Time: 00:57, VBatt start/end: 12.1V/12.1V)-----------
www.Ross-Tech.com
Revision: 00H35001
Coding: 0017665
Revision: 00005001
Coding: 0000001002
Revision: 00103 AG
Coding: 00D7B7
Coding: 0730ED
Coding: 100001
Coding: 0012343
Coding: 0000003
Coding: 110800
Coding: 000000
Coding: 0004854
1 Fault Found:
Revision: 00H17000
1 Fault Found:
000 - - - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 116447 km
Time Indication: 0
Date: 2016.02.16
Time: 02:54:01
Freeze Frame:
DD
Temperature: 38.0°C
Count: 2
Count: 0
SteerAng n.Init
Coding: 0004854
Coding: 0000144
Coding: 0000144
