MrMetal
It's actually a pretty easy install... one thing though, do yourself a favor and order extra rivnuts! Those things are an amazing pain in the ass to install... BUT, here is a trick. Go pick up some... hrm... not sure what to call them... self-locking washers? Not the kind that's just cut in one side and slightly offset, that won't do... you want the ones that looks like a star, with a bunch of small, sharp, twisted ends on the inside (or outside) of the washer... now, place one of those between the T-bracket and the rivnut, and then thread the screw through... now when you lift the assembly into the frame to expand the rivnut, the spiky washer will prevent it from twisting! It works like a charm, as long as you keep pressure on the bracket to make sure that the rivnut mushrooms INSIDE the frame, not partially out or totally on the wrong side (heh... yeah, I had both happen). Good luck, and let me know if you have any questions.
