Show me your tires.
AUGSX
Miami, Fl.
2001 Jetta GL TDI 5spd
So it's about time for me to put new shoes on the car and I am trying to decide between 205/60/15s or 215/60/15s. Tire rack recommends 6.5" rim which I have for both. I am looking for some pics to see if they are going to bulge out or balloon up to much.
Lets see them...
Lug_Nut
Sterling, Massachusetts. USA
none, 2014 Chevy Volt, 1988 Bolens DGT1700H
Go to the tire store with a tape measure. Measure the width of the bead on some different 205 and 215 tires. If the tape shows 6 1/2 that's about what the tire will look like. If the tape reads 7 then the beads will be pinched a bit when mounted on a 6 1/2.
Honestly? The 10 mm tire 'width' difference may be only 1 mm. This number is rounded up or down to the nearest x5 mm. From 200 to 210 are '205', From 211 to 220 are '215'. And besides, the 'width' when mounted will be determined by tread width and rim width. A 215 on a 6 1/2 rim might be narrower than a 205 on a 7.
coalminer16
Central Wisconsin
Golf 2004
I am thinking of tires soon as well and would like the tallest tires for a 15 inch OEM rim. I will do some searching when I get closer to that time.
52172
Buellton, Ca
2001 Golf TDI GLS
You could run a 195/70/15 or go to a 205/65/15. How much height to the tire do you want to gain? I know the 205/65/15 is 1/2 inch taller. I'm gonna go that route to correct the speedo. I wonder how much it will hurt my gas mileage? Shouldn't be to significant.
AUGSX
Miami, Fl.
I don't want to go higher just wider. The 2 sizes I posted are stock height just wider. Actually the 205 is .3" shorter than stock that is why I am more inclined to go with the 215. I really just want to see them mounted on a 6.5" rim to see what they will look like.
KITEWAGON
Seacoast, NH
2014 Touareg Exec, 2014 JSW
I honestly don't think you are going to be able to tell the difference in a photo. I had a set of mounted 215/55/16's and 205/55/16's side by side last week (on identical rims, not on the car) and absolutely could not see a width difference. I ended up tossing the 205's because I saw a slit in on of the sidewalls so I never put them both on the car.
If you just want wider and not higher then I think 205/55/16 is the stock 16" size for this car. Not 205/60/16. OEM's are 195/65/15 and the 205/55/16 is the closest match that you can get and the 215/55/16 are very close as well.
http://www.kermatdi.com/servlet/-strse-template/tirecalculatorandcomparator/Page
Doh! - I just saw that you are talking about 15's. Disregard the second part of my post.
Seatman
Scotland
2007 Seat Alhambra 2L tdi
195 on 6.5j rims is fairly tight, I think 205 is pushing it a little bit, check it out on a ruler, 6.5inches against 195 mm but as for which ones the uniroyal rainsport 2's are pretty superb for grip in all weather and that's what I use.:)
AUGSX
Miami, Fl.
Recomended rim size for a 195 is 6" according to most tire manufactures. What are you checking to base this on?
Seatman
Scotland
My wheels, they're 6.5j and I run 195 tyres but 6.5j is 6.5 inches so check it against 195 mm and you can clearly see that 195 is like 7.5 inches.:)
AUGSX
Miami, Fl.
yes but the 195mm is measured to the outside of the side wall not the bead were the tire meets the rim.
Seatman
Scotland
Yeh I know but there's no advantage to 205's on the 6.5j rims, the 195's actually look good on 7in rims, that's what was on my old Mk1 toyota mr2. I get 195/50/15's for a really good price but to go the extra to 205's would cost to much, maybe they're cheaper where you are because they're more popular. The other thing is you just end up with more of an angle on the side wall.:)
