crisp006
So here’s the deal. I killed my Jetta by hitting a rock and starving the engine of oil and am in the middle of swapping in a replacement engine (which I’ve already replaced the timing belt on).
As it so happens, I’m leaving the country in a few months (yeah, it’s silly to revive a car if I’m moving away, but I’m attached to my TDI and will be visiting at least once a year so I’ll have a vehicle to drive when I do), so I want to spend as little money as possible on this engine swap.
Now my question is this: if the car is only driven 2,000 km ish (1242 miles for you Americans and Brits) per year for the next 5-8 years (how long I plan to be away for), will this clutch, pressure plate, and flywheel likely hold up without grenading in spectacular fashion?
My feeling is the clutch disc itself will be fine (it has a minimum of 1mm before it hits the rivets), and total thickness of about a quarter inch, and the flywheel itself isn’t in the best of shape but is OK. What I’m most concerned with is actually the pressure plate. Would any experts on here be able to chime in about whether those 4 small cracks are a normal sort of occurrence and whether there’d be a risk of them expanding in a fashion that’d make reusing this clutch assembly in general not worth the risk?
Could anyone chime in with any thoughts on this or more generally the useability of the entire clutch assembly as pictured for another 10,000 miles maximum?
I don’t need any lecture over how you think I’m a cheapskate because I’ve invested plenty of money getting a replacement engine and timing belt kit etc (plus my time ... ) for a car that realistically I should’ve scrapped. The reason I want to save this car is because it has sentimental value (belonged to my grandmother) and I’m attached to it. I’d much rather spent that $500 ish (Canadian) on a clutch kit in 5-8 years upon my return than spending it now when money is tight. But obviously if you think it’s in absolute, unequivocal, dire need of replacement (or I might send the assembly through the bell housing at 3800 rpm!) please let me know.
Thanks in advance if you can provide any constructive feedback!
