Yes, it can be deleted.. Use vag-com enter Adress 17 for intrument cluster, then recode. I am not too sure which numbers are the ones that you remove and add zeros, but write the original values down so that you can go back to them if needed. You will be able to see the changes you make. IE: The clock will change from military time to civilian 12 hour. Just play around with the numbers and you will figure it out. That is the way I did it on my 05 Jetta as well as an 05 Passat wagon. When I did the Jetta a pop up box appeared in VaG-COM telling me what numbers applied to what feature. The 05 Passat did not. Each 2 numbers changes a different feature of the cluster. Good luck, I hope this helps. Joe@dieseltuning.ca
Note the link to Ross-Tech that explains the coding changes required to remove the seat belt chime. I did the mod to remove the chime, and I am a person that always wears a seat belt and demands that all passengers do the same. I just don't want to be nagged when the car is in the drive way.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
