tgray
- Joined
- Sep 12, 2004
- Location
- Marengo, IL
- TDI
- '02 Beetle, '05 Golf, 2000 Jetta, 2001 Jetta, 2002 Jetta
Here is what I know.
1. There are no codes shown on VDS and no light on the dash (the light works).
2. ABS seems to funtion properly on dry pavement or gravel.
3. ABS locks up and will NOT release the wheel(s) until car comes to a complete stop when stopping on snow or ice. This condition is consistent over and over. The brake pedal is not sticking.
4. ABS feels like it is pulsing and acting correctly as the car is slowing down, but the car will keep slowing down (skiding a wheel(s)) until it stops.
5. Brakes do not stick when pushed hard and not in a skid condition.
6. Brakes locking condition is only when the ABS pump is activated.
7. With ABS fuse pulled there is never an issue with brakes locking or sticking on.
Here is what I have done.
1. I had changed the original module because of a power failure code but still had the code with the new module. I found the problem was the fuse panel corrosion
2. This new module was locking the wheels just like mentioned above. So I assumed it was a bad used module I purchased. This one would lock up even on grass or gravel just like above statements.
3. I reinstalled the original module and it seemed all good until the first snow encounter and it too is locking up as stated.
4. I have bled the brakes and pedal is firm.
I have searched and found no other returns on this forum but did find someone with the same symptoms on the google search. All of the solutions that were given were wrong for these cars.
