Kyle99TDI
I recently finished replacing my clutch and changing the transmission fluid. I had some axle boots that were torn apart and spraying grease everywhere so I decided while I had the transmission out to replace the axles and axle seals.
When putting the axle flanges back in there is a small bolt that goes in the center of the flange and holesit to the inside of the transmission, you have to compress the spring on the flange to even get the bolt to reach. Does anyone know the torque spec on this ? I torqued it tight and then a little extra initially. Now I’m getting some fluid leaking on the passenger side axle seal and it’s spraying all over the back side of the engine. I did initially overfilled the transmission just a bit by not waiting for the stream coming out of the fill port to completely stop. Would it leak out of this seal if it were overfilled?
Not sure if I need to rip this thing all back apart and replace the seal again? Or retorque that axle flange bolt.
Any thoughts would be greatly appreciated.
