owr084
When I was changing the rear pads of my Passat, I found one of the rubber dust(?) seals was torn. The caliper is undamaged and it is not leaking any fluid, so I am not going to pull the piston to replace the seal.
My question is what should I use to clean the area around the piston and under the dust seal - brake cleaner or something less harsh?
